It is currently Mon May 04, 2026 7:36 pm
PostPosted: Thu Jul 15, 2010 12:56 am
got a stock dual port 1600 ..... how much compression does each cyl supposed to have? it does run j/w wat their supposed to have
If your not God, then don't judge me
PostPosted: Sun Jul 18, 2010 8:53 pm
About 71/2 to 8 to 1 stock
PostPosted: Sun Jul 18, 2010 11:09 pm
Rebuilt one and had 120. I think the book says less than 90 will work but 60 needs attention. It's hard to lite off fuel with low compression especially if the air/fuel is escaping.Pull up a vw beetle forum under something like Type 1 compression low or something. You may get a better answer.
PostPosted: Mon Jul 19, 2010 5:11 pm
Most new stock vw 1600s have 115 lbs.
A good used stock 1600 should have at least 100 lbs. with no more than 10 lbs difference from one cylinder to another.
When checking compression, warm the engine up first, and check valve lash to get a true reading.
