 Post subject: what size engine
PostPosted: Wed Jul 14, 2010 8:40 pm
hey if anyone can help. i just bought a buggy with an unknown moter size i think its stock but how do i tell for sure
thanks
 Post subject: Re: what size engine
PostPosted: Wed Jul 14, 2010 9:04 pm
No way to know for sure without removing a head.
PostPosted: Wed Jul 14, 2010 9:33 pm
ok thanks
PostPosted: Thu Jul 15, 2010 12:38 am
Do you have a single or dual port intake manifolds?
PostPosted: Tue Jul 27, 2010 6:31 pm
its a single
PostPosted: Tue Jul 27, 2010 8:29 pm
If the intake manifold is a single tube going to the heads, then the engine is either a 1200 or a 1500.
PostPosted: Tue Jul 27, 2010 11:51 pm
there were 1300 factory single ports, too. Most common found is the 1500 though.
PostPosted: Mon Aug 30, 2010 10:25 am
Look at the front of the engine, right below the alternator-generator stand. Might need to clean it up or take something off but there is a serial number there (the stand has the engine-s firing order on it) that starts with a letter, i.e. B6337458. This doesn't apply for crate engines for aftermarket blocks from JC Whitney.
Anyway write down that number and look here: http://type2.com/bartnik/enginecodes.htm
This will tell you the year and displacement of your engine. Hope this helps.
The fastest animal on earth, with a top speed of 120 feet per second, is a cow that has been dropped out of a helicopter.
