will a standard vw fuel pump push dual 44s
http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=988
Author:  joshua53 [ Sun Aug 19, 2007 7:09 pm ]
Post subject:  will a standard vw fuel pump push dual 44s
i have a 2332 with dual 44s 44x39.5 cb heads 11.0 to1 compression will a coustom ground cam with 1.25 rockers will a vw fuel pump push that much fuel
Author:  Odyknuck [ Sun Aug 19, 2007 8:15 pm ]
The stock pump will supply enough gas for the carbs however its the pressure you have to be concerned with. Put a pressure regulater in line and set it at 2.5 to 3 PSI.
