PostPosted: Tue Jul 06, 2010 2:32 pm
I have a buddy that I'm bulding a buggy for he has a stock 1500 and a single weber 44 and he has left me to get the rest of it to work. I'm thinking that there is now way to choke down a 44 weber and still have it work. Am I wrong?
|....BUDWEISER......| ||'|";, ___.
|_..._..._______===|=||_|__|., ] -
PostPosted: Thu Jul 08, 2010 7:43 pm
the carb will probaly work but it will get aggravating,it will probaly nee smaller venturas and different mains and different idles,if u got the time and money it should work or trade it for a progressive carb and intake
PostPosted: Thu Jul 08, 2010 7:50 pm
it will get aggervating, i tried to put a 44 on a 1600 dual port and it woud just foul to plugs and wouldn't run right, i put a progressive 36 on it and it ran great so good luck :mrgreen:
PostPosted: Fri Jul 09, 2010 7:37 am
I will tell him that he need a differnt carb or a bigger motor.
PostPosted: Sun Jul 11, 2010 9:50 am
Did he listen?
PostPosted: Mon Jul 12, 2010 8:21 am
perrib wrote:
Did he listen?
He is still thinking..... this could take a while... :D
PostPosted: Mon Jul 12, 2010 11:40 am
Give him some facts. First one is the system needs lots of preheat. Unless he has a lathe and a good selection of jets and air correctors he'll need custom made venturies since Weber does not make 24, 26, 28 mm venturies for 44s. Who knows which one will work best. Last ones I had made were $25 each. Next I would expect around $200 worth of jets and air correctors. Never mind all the hours you'll have in it seeing what works best and playing with acc pump adjustments. All that for less than 4 horsepower.
PostPosted: Wed Jul 14, 2010 8:29 am
Your right now he wants me to build him a motor. I think the single 44 would best fit a 1900cc. Thnaks for all the help.
PostPosted: Wed Jul 14, 2010 12:03 pm
:) Now he will have a good engine.
