 Post subject: Questions on Baby Dels
PostPosted: Wed Jun 09, 2010 7:21 pm
Hi Guys
Got my engine running and for a used 1700 it sounds pretty good.
I don't know what has been done inside but outside it has a 099 dist I think and a set of supposedly new Baby Dels.
My question is when idleing it pops a little not sure why and it has alittle blowby that smells more like gas than oil. Was wondering if the carbs were set up right for this engine sinse the kid I got it from didn't know anything about them except he bought them new in the box and bolted them on but then lost intrest in the project and stoped there.
I guss what I am asking is can someone walk me through setting them up or do I need to take it to a pro.
Or is there a web site that has set up procedures?
Also I have the red wire from the alt hooked up to the starter but dosen't seem to be charging there is several other wires coming from the alt dose one of these need to be hooked up to make alt charge??
Any info , Ideas, or comments welcomed.
MoblMec
PostPosted: Thu Jun 10, 2010 1:33 pm
it may be an external regulator alt.,,need some pics,,,ur carbs jus sounds likt the idle air screws need to be adjusted
PostPosted: Sun Jun 13, 2010 10:54 am
i agree with the idle screw. make sure all of the gaskets are good and they are tightened down good...onew more thing could be just jetted wrong
PostPosted: Fri Jun 18, 2010 11:13 am
Make sure that your fuel pressure isn't too high.
