It is currently Mon May 04, 2026 4:33 am
 Post subject: carbs
PostPosted: Wed Jun 09, 2010 4:16 pm
hey everyone , havent been on in a little, but my buggy is almost completed. my next step is to find some good but CHEAP carbs, i know that doesnt usually happen. i found a single weber one ebay for about 350.00 can you all give me some options for a 1600 dual port?
i would appreceiate it thanks.
 Post subject: Re: carbs
PostPosted: Wed Jun 09, 2010 4:56 pm
"Good but cheap carbs" You can not have both. A single weber 40 would be a good selection for you. Stay away from the EMPI knock off.
PostPosted: Wed Jun 09, 2010 9:06 pm
k so would something like this work.? http://cgi.ebay.com/ebaymotors/Weber-40 ... 53d1fc2552
PostPosted: Thu Jun 10, 2010 10:02 am
i wouls look for a Dellorto like a 36 or 40
PostPosted: Thu Jun 10, 2010 11:54 am
i hate empi's deff. stay away from them. they are nothing but trouble but they can be fixed. the most common problem ive seen out of the empis are the chok tubes pop up and it loads the carbs on you. we made some aluminuim plugs and pressed down in the bore and they haven't been popping out. another guy i ride with tapped the bore and put a set screw down in there works aswell
PostPosted: Thu Jun 10, 2010 12:07 pm
i've done the same thing to my webers!
