PostPosted: Wed Jun 09, 2010 6:37 am
What size cans are you guys running? I bought 6 quart but i think they are too small. the top filter base fits snug in the bottom, but i think the sides will be too close to the filter. suggestions?
PostPosted: Wed Jun 09, 2010 6:49 am
I’m not sure what size mine are but running the short 4in. air cleaners with foams. My top lip defiantly does not fit snug! :!: Got them at Wal-Mart for 5 bucks ea. And have about 1.5 to 2 inch of air space underneath. I had to cut the back side out a little for linkage and oil lines also pop riveted some thin aluminum to under side to stiffen them up. If you need picks let me know. I want to say mine were like 8 gal. Or some thing. I took my top air cleaner lid with me. :mrgreen: :lol:
PostPosted: Wed Jun 09, 2010 8:46 am
Thats prolly about right. My top filter base is so snug it stays in the can when I lift it all off.
Might wanna try to find cans that aint concave on the bottom. They will puddle water on them, like mine do.
PostPosted: Wed Jun 09, 2010 9:27 am
I can make you a pair like the ones that are on my buggy if you want and i can bring them to wheeler's if your coming?I make them out of aluminum on my brake and rivet them together for a clean look.Just let me know what the exact width,length and heigth is and i'll make you a set up,no charge.
PostPosted: Wed Jun 09, 2010 3:57 pm
thanks guys... Larry, you don't have trouble with them breathing since they are so close to the filter at the top? do you have the foam pre filters on? mine are concave, but my studs are long enough i think i can put a nut on to hold the base on then the cans, then a wing nut so i don't have to worry about the water leaking in.
bucky,
i really appreciate the offer, i'm not 100% sure if i'm coming yet or not, i want to. i will let you know when i find out. i run webers with 6 inch filters and aluminum bases for the record...
PostPosted: Wed Jun 09, 2010 7:50 pm
Does anyone have pictures of this?
PostPosted: Thu Jun 10, 2010 12:41 am
Jeff, I used to run foam prefilters with no cans on weber 44s. When I switched to cans and no prefilters, I couldnt tell a difference at the start of a ride, when everything was clean. But after riding a day, especially if it was muddy, the prefilter setup would get dirty and I'd get clogged idle jets way more than when I switched to cans with no pre-filters. I dont know if one actually flows better than the other, but the reduced aggravation was worth any flow difference that I could not even feel. The cans I got kinda flare outward as they get towards bottom of the carbs so they arent real close to the filters all the way down the height of the filters.
PostPosted: Thu Jun 10, 2010 12:54 am
I bought plastic zip lock brand clear rectangle bowls for 3 bucks at dollar store
PostPosted: Thu Jun 10, 2010 10:26 am
I got a feeling I know who's about to jump in this thread, since we said "idle jets".... :roll: :lol:
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Thu Jun 10, 2010 11:19 am
Im not saying Dellortos are better than Webers but ive been much better off with Dells when it comes to idle jets,knock on wood.If you run the good fuel filters,not the clear ones with the paper elements and grease the top and bottom of you air cleaners and use K&N filter oil,you should highly increase you luck on having clogged jets.
PostPosted: Thu Jun 10, 2010 3:12 pm
Here are a few pics of my filter coversImageImageImage
PostPosted: Thu Jun 10, 2010 11:40 pm
I agree with ya about the Dells not clogging near as bad. I have only had to take out an idle to clean it once in the woods since I switched to them. Every now and then it'll sound like one is clogging, then clear up on its own. I guess it may be because usually a Dell will take about 5 numbers bigger idle jet than a weber on the same engine and crap gets thru it easier. idk?
PostPosted: Fri Jun 11, 2010 6:09 am
well i ordered jet doctors last night, hopefully that will help some too... looks like i am most likely coming to wheelers then, pipedopes got me pretty convinced to make the 4 hour trek lol.
PostPosted: Fri Jun 11, 2010 1:54 pm
If your using CB's base's ill go ahead and make you a set and you can decide if you want to use them or not when you get there.
PostPosted: Fri Jun 11, 2010 5:39 pm
yeah i do believe they are cb bases, because they match the one i bought for my single dell. thanks buck i appreciate it!
PostPosted: Fri Jun 11, 2010 6:19 pm
Glad to help anybody keep idle jets clean.
PostPosted: Mon Jun 28, 2010 4:48 pm
Take one of your air filters to walmart, target, marcs or where ever and just keep trying cans. I'm running a single carb, but I found a pot at target that fit nicely. I just cut the handle and lip off, painted it, and it works well.
