| Installing oil stat http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=9622 |
| Author: | Dave Winterburn [ Fri Jun 04, 2010 3:46 am ] |
| Post subject: | Installing oil stat |
I've run full flow systems before, but now am adding an exernal cooler also. The oil stat has no instructions |
| Author: | perrib [ Sun Jun 06, 2010 7:08 am ] |
| Post subject: | Re: Installing oil stat |
If it is the Empi T-stat Oil should flow as follows. A. From engine to port marked E-1 port. B. From port marked C-1 to oil cooler. C. From the cooler to port marked C-2. D. From port marked E-2 to return in engine. I have mine installed so the feed is from the outlet on the oil filter. |
