 Post subject: solid rocker shafts
PostPosted: Mon Mar 15, 2010 2:35 am
Just wonder what the proceedure is for the end bolts on solid rockers. Are they lock tited and torqued, or just tourqued and how much?
 Post subject: Re: solid rocker shafts
PostPosted: Mon Mar 15, 2010 11:45 am
I use a star type lock washer. The spec for 5/16 NF thread is 14 ft lbs. Lock Tite may be over kill I have broken shafts but never had the end bolts get loose.
PostPosted: Tue Mar 16, 2010 1:26 am
Thank you! :D Just thinking in hind sight, the bolts have like a built in star washer. So 14 lb.s should be good?
PostPosted: Wed Mar 17, 2010 7:45 pm
It will work.
