It is currently Mon May 04, 2026 7:39 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
PostPosted: Thu Feb 25, 2010 6:36 pm
HI JUST BOUGHT A SET OF ITALAN WEBERS AND I CAN THEM SET UP WONT IDLE. BUT WHEN U HIT THE GAS THERE ON IT, THROTLE RESPONSE IS CRAZY ,RIGHT THERE. SO MY PROBLEM IS ITS NOT IDLING AND WHEN IT DOES ITS BARELY RUNNING AND RUNNING RICH
PostPosted: Thu Feb 25, 2010 6:48 pm
sounds like its getting to much fuel at idle.chad :mrgreen:
PostPosted: Thu Feb 25, 2010 7:00 pm
also do i need volocity stacks
PostPosted: Thu Feb 25, 2010 7:02 pm
ive tried running the fuel screws in and setting them all to like one turn out or 2 turns out just cant fugure it out carbs isnt my best thing :twisted: :twisted:
PostPosted: Thu Feb 25, 2010 7:49 pm
Did you sync the two carbs . IF NOT YOU HAVE TO.
PostPosted: Thu Feb 25, 2010 8:13 pm
What size are the idle jets?
PostPosted: Thu Feb 25, 2010 8:28 pm
http://www.woodsbuggy.com/index.php?option=com_jfusion&Itemid=10&jfile=viewtopic.php&f=3&t=8449
http://www.woodsbuggy.com/index.php?option=com_jfusion&Itemid=10&jfile=viewtopic.php&f=3&t=8573
Both these threads should help. You probably have F11 tubes. Those will be fine.
PostPosted: Thu Feb 25, 2010 8:47 pm
i get on side to run right than the other side wont idle right and i yes i syned them but i just found out that the left side intake is cracked just seen it so there one problem and now the other problem is finding a new intake set any ideas
PostPosted: Thu Feb 25, 2010 8:50 pm
check the damn idle jets! constand annoing ass problem i have delt with too much. the smalles bit of crap in one of the jets will make it run like shit. start the engine and let it get hot at an idle. lick your fingers and touch each one of your exhaust pipes seperatly. if you find a cold one take that cylinders idle jet out and i bet you find some junk.
PostPosted: Thu Feb 25, 2010 9:01 pm
thanks for the info thats wat i did and its still running like shit the left side intake is cracked so i think that is the problem im about to just put my single back on it this is too much of a pain in the ass :evil: :evil: :twisted: :twisted:
PostPosted: Thu Feb 25, 2010 9:08 pm
they are good carbs made my 2332 run like a raped ape! but yes duals are a giant pain in the ass in the woods. mine always drown the enging while trying to idle down a hill but if your foots in it hold on. just running a small engine like you are i would prolly run a single as well.
PostPosted: Thu Feb 25, 2010 9:17 pm
i mean i have built the hell out of this motor and every one i ride with tells me that i need the dual carbs and that im not getting enough fuel im going to try changeing sum jets around and c wat happens thanks alot man for the info
PostPosted: Thu Feb 25, 2010 9:18 pm
That cracked intake is an issue. I would not have traded my dual 44's on my 1915 for anything.
PostPosted: Thu Feb 25, 2010 9:19 pm
do u run vocecity stacks in ur dauls
PostPosted: Thu Feb 25, 2010 9:22 pm
Absolutely. 4" stacks inside 6" filters.
PostPosted: Thu Feb 25, 2010 9:25 pm
the intake is a big problem. its leaning one side out WAY to much. and a 1915 will run great with dual carbs, so does just about everything else. i just had shitty luck when it came to putting around it was all or nothin.
PostPosted: Thu Feb 25, 2010 9:37 pm
i have dual webber 44's on my 1915 but i think i need to clean the idle jets on it, whitch is the idle jets
and where can i get a airfilter i
PostPosted: Thu Feb 25, 2010 9:40 pm
Those are the ones on the side of the carbs.
PostPosted: Thu Feb 25, 2010 9:48 pm
ok thanks but can i get a air filter at advance auto parts or somewhere
PostPosted: Thu Feb 25, 2010 9:57 pm
Not that fits a Webber. VW suppliers or buggy shops or ebay.
PostPosted: Thu Feb 25, 2010 10:01 pm
how expsnsive are they
PostPosted: Thu Feb 25, 2010 10:14 pm
20 bucks for a cheapie. Ive got over 200 in my set of billets. It depends on what you want to spend.
PostPosted: Thu Feb 25, 2010 10:18 pm
i just want a cheap set
PostPosted: Thu Feb 25, 2010 10:23 pm
http://cgi.ebay.com/ebaymotors/EMPI-8714-VW-BUG-WEBER-40-48-FILTER-3-1-2-HIGH_W0QQcmdZViewItemQQhashZitem48351d8326QQitemZ310128771878QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
This is about as cheap as it gets. They work fine.
PostPosted: Thu Feb 25, 2010 11:51 pm
is that for one set or for one filter
