It is currently Tue May 05, 2026 2:31 am
PostPosted: Wed Feb 17, 2010 6:55 pm
I've been shoping around looking for heads for my rail. I found a set of Mofoco 050 heads that look decent for the price and I'm trying to find sum feed back on them I have stock heads now and it just doesn't have wat it should
PostPosted: Wed Feb 17, 2010 7:18 pm
alot of that will depend on what kinda riding your going to be doing,carbs and cam your running.ive heard good and bad things about these heads,but the mofoco heads my buddy runs have never had a problem and he has the 042 and the 050 heads.those 050's maybe just a little much for that 1915 for lugging around the woods imo.chad :mrgreen:
PostPosted: Wed Feb 17, 2010 7:20 pm
on the 050s check the valves where the keeper go and check the guides to make sure their tight in the casting just send a set back to mofoco to get fixed for these problems
PostPosted: Wed Feb 17, 2010 9:30 pm
What cam, carb, gear ratios and tire size do you plan to use?
PostPosted: Wed Feb 17, 2010 9:36 pm
its a 1915 with 110 cam,1.25 rockers,single webber 44 , lightend flywheel ,sraight cut gears ,high volume pump, i have tired a set of 042 heads with stock rockers and it still acts like it does have any low end i was tring to get sum info on these mofoco deals and sum feed back on wat other people are running thanks alot for the info if you got and other ideas throw out there im always whilling to try anything
PostPosted: Wed Feb 17, 2010 9:38 pm
i have cut 31/15.50/15 firerstone v bars with 6 rib i do believe that its a 4.56 and it has super diff and have duty side plates
PostPosted: Wed Feb 17, 2010 10:14 pm
For heavy tires and a single carb stepping down a cam size to a VZ 14 cam or FK 41 cam makes a big difference. What bugs me about Roys 050s is he won't post the flow and air speed specs on them but claims they flow the best of any unported similar head. You might want to check out Steve Tims Stage One heads at performance-workshop.com. They are priced right at $590 and he will set up the valve springs for your cam and port match your intakes for that price. You should be able to pay a little more and get the head volume set to run .050 deck. Along with the Stage One heads you could also slip in a 78 mm crank and keep the 110 cam.
PostPosted: Wed Feb 17, 2010 10:22 pm
now with that crank i do i have to machaine the case at all
PostPosted: Wed Feb 17, 2010 10:41 pm
If you use CB Unitech or Scat I beams you should not need to. Stroker clearanced stock rods require lots of case clearancing and checking rod to piston clearance, as the piston is at BDC the opposing rod can tap it wiping out a rod bearing.If you get the crank built with Buick Journals and use H Beam rods there will be room to spare. Every once in a while something is off so I always check to make sure there is .040 cleaerance. You will need stroker pistons. Keeping it a 1915 is simpler to build.
PostPosted: Thu Feb 18, 2010 8:14 am
hi i got a 1915 with engle 110 cam and a single weber 44 hooked to a 6 rib bus tranny, not sure on rockers i will check! i am using a set of OUTLAW 044 heads i have tons of torque and she will climb any hill you aim her at :lol: she will scream also!! extremely happy with this setup, great all aroungd performance and driveability. mine is also street legal and it will very easily keep up with the traffic SSHH!! well!! what i meant to say is the traffic can barely keep up with me :lol: VVVROOOOOOOOOOMM
PostPosted: Fri Feb 19, 2010 11:27 pm
Does any1 know how to measure deck height
PostPosted: Sat Feb 20, 2010 1:11 am
You can bolt a deck hieght tool over a cylinder and use feeler guages or a dial indicator to measure the distance from the top of the piston to the top of the cylinder when the piston is at TDC.
http://www.chircoestore.com/catalog/pro ... ts_id=2323
cron
