It is currently Sun May 03, 2026 10:39 pm
PostPosted: Tue Feb 16, 2010 10:44 am
Alright, last time out i was having problems keeping running, revving up, and i couldnt keep a constant rpm. i was told therewas supposed to be a check ball in the squirter jets, is that correct?
PostPosted: Tue Feb 16, 2010 10:44 pm
What kind of carb??
PostPosted: Wed Feb 17, 2010 10:18 am
progressive
PostPosted: Wed Feb 17, 2010 11:16 am
You might have dirt in the bowl. I like to use a Bosch fuel filter for a Digifont 1988-1992 VW. It has 5/16 inlet and out let for push on hoses. Correct fuel pressure is critical to getting those beasts to work. If the pressure is off anything else you do also is off.
Here are some links with good set up information and diagrams.
http://www.redlineweber.com/html/Tech/c ... _best_.htm
http://www.redlineweber.com/html/Tech/3 ... akdown.htm
http://www.theautoist.com/weber_carb.htm
PostPosted: Wed Feb 17, 2010 11:38 am
No dirt in the bowl. We cleaned it trying to get it to work. Then later i was told to check and see if there was one in there and there wasn't (refferring to the check ball in the squirter jet)
PostPosted: Wed Feb 17, 2010 4:36 pm
One of the links is an exploded diagram of all the parts to a Weber progressive. I have not used that style carb in many years as it is a royal pain to keep R&Ring it to work on it so i don't remember. With work I have gotten them to run well. Once you get the pump to squirt,start by checking your fuel pressure as if it is out of range all the other adjustments will be off.
Another Weber progressive link
http://vw.zenseeker.net/WeberProgressive.htm
PostPosted: Fri Feb 19, 2010 10:53 pm
Did any of those links help?
