PostPosted: Mon Dec 28, 2009 1:38 pm
ok so the stock type1 studs will not come through the 3 rib transaxle so i need the longer studs whihc are about 90mm...
where can i find these :?:
or does anyone have 2 that they can part with...
ian
910-520-2126
PostPosted: Mon Dec 28, 2009 1:44 pm
ian
910-520-2126
Get a piece of metric all thread.
Local hardware probably has it.
10mm x 1.5 pitch and cut whatever length you need
PostPosted: Mon Dec 28, 2009 2:44 pm
ty man...i called granger and they have studs of 10 x 1.5 x 95 so i might go that route...ty for the idea if that does not work out...
PostPosted: Mon Dec 28, 2009 8:51 pm
take a old 10 mm case stud and cut it to length ,run a 3/8 die on it use 2 3/8 flanged nuts :idea:
