It is currently Tue May 05, 2026 1:15 am
 Post subject: bus engine???
PostPosted: Thu Dec 10, 2009 3:15 am
I have been lookin around for a motor for my buggy and i ran across a complete bus engine and automatic or stickomatic tranny for 300 bucks :) i dont plan to use the trans but i was wondering if anyone had any info .is this a good deal , r they worth fooling with,part availability,do they make good power,im lost :?
 Post subject: Re: bus engine???
PostPosted: Thu Dec 10, 2009 7:04 am
Get the engine code. Is it F.I. or does it have carbs? Thanks Dave T
PostPosted: Thu Dec 10, 2009 9:14 am
not sure,but ive herd a set of headers for a bus motor are bout 300.00 and the exhaust ports i guess is what call them makes you loose about 3 in. of clearance
Brandon
PostPosted: Thu Dec 10, 2009 9:25 am
make your own headers. would look like what the suby would run.
PostPosted: Thu Dec 10, 2009 4:44 pm
i dont have the engine code but it does have dual stock carbs.i saw a exaust set up in jc whitney for around 60 or 70 bucks it has a cherry bomb type muffler on it.this may sound dumb but this is a type 4 motor isnt it :?
PostPosted: Thu Dec 10, 2009 4:53 pm
i also have a buddy with a buggy that has a bus motor he got it running and together mostly and parked it like a year and a half ago it also has dual stock carbs i would like to get it also and use it for parts the frame has rust holes in it and it is a very short buggy.i think 400 to 450 would get it :wink:
PostPosted: Thu Dec 10, 2009 5:31 pm
:shock:
dont know bout that but check around the samba they should have a set of used headers
Brandon
PostPosted: Thu Dec 10, 2009 6:21 pm
Yes they are called a type 4 engine also. If the engine has the 3 stud intake manifolds then it could be a Porsche engine :D http://www.tunacan.net/t4/index.shtml This link can help a lot. Thanks and do you have any pics?? Thanks Dave T
PostPosted: Thu Dec 10, 2009 9:56 pm
thanks for all the info guys that type 4 site is awsome and i will definetly check out that samba site for headers.cant thank yall enough :D :D :D
PostPosted: Fri Dec 11, 2009 1:30 am
not trying to hijack thread but cant the type 4 engine be built to like a 2900 or so ?
if so what size crank and jugs do they use?
PostPosted: Fri Dec 11, 2009 2:05 am
2980?
PostPosted: Sat Dec 12, 2009 3:39 pm
84 crank with 105pistons http://www.europeanmotorworks.com/vw/ty ... Parts.html this will net a 2909 :twisted: If the engine has the heater boxes on still, cut the flanges off and weld up your own exhaust. Thanks Dave T
