 Post subject: My ported heads
PostPosted: Thu Dec 03, 2009 10:08 pm
I am not an engine builder but I think these heads look pretty kick ass. I am not sure if the pics will show this very well but I am excited how well they turned out.. Once the new case is deburred, we can put the engine back together.
Before...
After...
Before
After
 Post subject: Re: My ported heads
PostPosted: Thu Dec 03, 2009 11:35 pm
I forget who, but someone told me not to open up the exhaust ports. Something do to with more torque?
Is this true anyone?
PostPosted: Fri Dec 04, 2009 12:27 am
I Hope not... :oops: :oops:
My theory is the more flow in / the more flow out...
PostPosted: Fri Dec 04, 2009 12:46 am
Yes it could cause torque loss. But properly ported heads will improve greatly. Most of all porting that needs to be done is the bowl of the head. What was done there was some gasket matching. Also when doing head work it is alwys a good idea to have them put on a flow bench to make sure everything is flowing equal. A totally balanced motor (including air/fuel) is a happy motor :mrgreen:
PostPosted: Sat Dec 05, 2009 8:10 pm
I had Jim from Jim's Custome VW port and polish my CB performance heads. You wouldn't believe the material he took out of the exhaust, those things are huge. They match up to my 1 5/8 headers.I get plenty of power out of those heads.
Dave
PostPosted: Sat Dec 05, 2009 9:24 pm
thats about how i did mine and a buddys heads like that DVS1drove the one buggy he said it was torquey :D i figured if you got it goin in fast gotta come out fast right :mrgreen: good job!!!!
PostPosted: Sun Dec 06, 2009 1:36 pm
Good job the more you do the more you lern . What is your compression & a small D port or oval works good on the intake
PostPosted: Sun Dec 06, 2009 9:55 pm
10-4 they look good.
PostPosted: Mon Dec 07, 2009 3:36 am
who all or should i say what shops have this capability AND understanding to give the CUSTOMER a finished product that performs like the customer wants and not what they "think the customer should have" ,,, if any of makes any sense :?:
PostPosted: Mon Dec 07, 2009 11:35 am
Don't know about up there but down here a man named Steve Sands is the best around here at porting and bench flowing
He knows how to make HP
lots of people think you need the biggest thing going on a motor .In my years I have found a good ported polished flowed set of half ass heads are better than a stock set of superflow
In my Harley days I found that's where the HP was was in the heads
PostPosted: Mon Dec 07, 2009 6:15 pm
Looks good MM . thats how I did the last set I done on a 2074 I had.
I bet you are chomping at the bit to get back in the woods !!!
PostPosted: Mon Dec 07, 2009 7:17 pm
not real sure where you are goin, but let me start of by saying im not knocking mm's work...hilliholic asked a ? and i replied. As far as capabilities...and shop who builds serious engines and does head work should have a flow bench. that goes along with performance also, you should be able to tell them what kind of power you want.
PostPosted: Mon Dec 07, 2009 8:26 pm
mm , what did you use to port ? one of the porting kits from like summit racing , just curius . thanks jason oh i think the heads look great !!!!!!!!!!
PostPosted: Wed Dec 09, 2009 10:41 pm
Fellas,
thanks for all of the support. I hope it runs as well as it looks.. :lol: :lol:
As for the tools, used a bunch of grinding and polishing bits. Set up with 9.8:1 compression. However, I will still be under-carbureted. I will have a 2276 with a single weber 40.
PostPosted: Thu Dec 10, 2009 8:29 am
You will never get it to run the best with one carburetor. It will always be starved for air. But you can make it run OK with just one.
PostPosted: Thu Dec 10, 2009 10:58 pm
I'm running a 500 holley 2 barrel and it seems to work pretty well. i was gonna go with duals but having second thoughts this seem to run very well for me.and i built the intake. i got the idea from a buddy of mine. :wink: :mrgreen:
PostPosted: Thu Dec 10, 2009 11:04 pm
Fellas,
your going to have fun jetting that carb to run on that motor,webers are pains in the ass when u run single carbs,and its probaly going to have to be jetted before it will run right
PostPosted: Thu Dec 10, 2009 11:36 pm
I dont want to hijack the thread but how did you get a Holley to function well on the hills? Ive never gotten one to work well on its side.
PostPosted: Fri Dec 11, 2009 4:38 am
chris38375 wrote:
Fellas,
I completely agree. I will probably upgrade to duals next year. I just ran out of money building the engine this year. In the meantime, a little re-jetting and things should run well enough.
Although, I have to say, I run into a LOT of people who claim their buggy's ran better on a single than duals.
PostPosted: Fri Dec 11, 2009 8:00 am
they do run better with a single,its jus getting them to run,mostly having a flat spot in the motor
PostPosted: Fri Dec 11, 2009 4:51 pm
all i did was change the acc pump from a 50 to a 30 and do a lil changing on the cam that controls the acc pump that good rid of the dead spot once in a while if you bounce around backing down a hill it'll mess up but it will clear right up.i hear the webers and dells do the same. it trail rides good and climbs good. i never did mess with the float level yet.
PostPosted: Sat Dec 12, 2009 2:30 am
I cured that problem in my Webers by running a Holley blue pump at 7psi & lowering the floats to about an inch from the bottom. Everybody said it would never work but it did. I thought you may have tried that approach.
