It is currently Mon May 04, 2026 10:42 pm
PostPosted: Sun Jan 03, 2010 4:09 pm
I have a set of 45mm Dells and they need the spindle bearings replaced in them both.I have slowly started to tear them down,one carb at a time and im not a pro when it comes to theses type of things.Is there a secret to getting the shafts out,i didn't want to beat on them if it was not necessary,but that is the only way i can think of to get them out.Also does anybody know of anyone that does rebuild these type of carbs?
PostPosted: Sun Jan 03, 2010 6:31 pm
u talking about the shafts the butterflys are on??
PostPosted: Sun Jan 03, 2010 6:52 pm
Yep.
PostPosted: Sun Jan 03, 2010 7:11 pm
i thought if u take ur linkage and the butterflys out they would comr right out
PostPosted: Sun Jan 03, 2010 7:36 pm
nope got tap on them very gingerly. :mrgreen:
PostPosted: Sun Jan 03, 2010 7:38 pm
Remove spindle nut,washers,butterflys, then side out spindle bearing and shaft from the linkage side.
At least that the way I remember it, but it's been years.
PostPosted: Sun Jan 03, 2010 9:10 pm
CB peformance sells a Update kit that changes the vertical discharge tubes to horizantal,claiming a huge difference,has anyone done this update to their carbs and if so how did they perform for you?
PostPosted: Sun Jan 03, 2010 9:50 pm
i know a lot of people put that update in webers and swear buy it,,, couldn't tell you about dels, but I assume the same? I wanted to get one back when I had my 1641 and single del 45, but cb didnt offer an update kit of the single carb they told me..
PostPosted: Tue Jan 05, 2010 1:46 am
i have a set of dual 40's dells and they need rebuilding where are u getting ur rebuild kits from and any info would be appreciated.
when in doubt gas it
PostPosted: Tue Jan 05, 2010 2:37 pm
CB performance has the parts
there is a guy named ART that you can send them to and he will send them back ready to go
Gary [Turbo Blue] probably knows who i am talking about .I used to know his # but not anymore
PostPosted: Sun Jan 10, 2010 2:08 pm
I cannot get the shaft out,ive broke the pump lever control arm that connects to the shaft.I didn't brake it by beating on the shaft,but when i was trying to take it off the shaft and it looks like it may be a hard part to find.Luckily i have a set of 40's that i can rob from.I have sprayed it with some lubricant and im going totry again later,but i dont want to bend the shaft by beating on it to hard.
PostPosted: Mon Jan 11, 2010 2:00 am
CB has a pars list for Dellorto DLRA
http://www.cbperformance.com/catalog.asp?ProductID=1245
#7294 Pump lever link $14.95
PostPosted: Mon Jan 11, 2010 9:18 am
This link is the guy rockrockets1 is referring to, He's "the man" when it comes to delorto's.
http://www.aircooledengineering.com/
PostPosted: Mon Jan 11, 2010 7:59 pm
You guys are right,this guy does know his stuff,thanks for the link.
