| GOTTA A MISS http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=7571 |
| Author: | davehix [ Wed Sep 09, 2009 9:24 pm ] |
| Post subject: | GOTTA A MISS |
o.k i got a miss i've check compression all 4 around 160 lbs i've changed wires,plugs,cap,rotor,sprayed for vacuum leaks seems to be the back 2 cylinders any suggestions. |
| Author: | Stevo [ Wed Sep 09, 2009 9:43 pm ] |
| Post subject: | Re: GOTTA A MISS |
Check rocker movement on the back two cyl. Maybe a lobe on the cam is flat since they share cam lobes. |
| Author: | davehix [ Wed Sep 09, 2009 9:56 pm ] |
they got good movement forgot to say checked that to |
| Author: | chris38375 [ Wed Sep 09, 2009 11:52 pm ] |
what kind of carb set up u have? |
| Author: | Odyknuck [ Thu Sep 10, 2009 12:52 pm ] |
Holley 4 barrel. |
| Author: | davehix [ Thu Sep 10, 2009 3:47 pm ] |
holley 500 2 barrel 4412 |
| Author: | afterburnt [ Thu Sep 10, 2009 5:09 pm ] |
what kind of ignition are you running? when i was running the 09 distributor, i was kind of having the same problem, it turned out the ignition wasnt hot enough to burn all of the fuel. you might want to try a little hotter coil, see if that would help. dave |
| Author: | davehix [ Thu Sep 10, 2009 8:57 pm ] |
SubySteve wrote: Check rocker movement on the back two cyl. Maybe a lobe on the cam is flat since they share cam lobes. O.K. i found it say i'm crazy but ..... finally had time to set down and do something so i had valve cover off driver side all the rockers was moving equally that why i said no flat lobes.none loose so i reset them and move to pass side . when i pulled the cover off i noticed no.1 exhaust rocker was backed off(IN A HURRY MUST HAVE FORGOT TO TIGHTEN DOWN) ![]()
| Author: | Odyknuck [ Fri Sep 11, 2009 4:29 pm ] |
Sorry I thought you said a 4 Barrel when we were looking at it over the weekend. davehix wrote: holley 500 2 barrel 4412
| Author: | aboone993 [ Fri Sep 11, 2009 10:54 pm ] |
what kind of manifold are you running ? Do they still make the Johnnys 4 play manifolds ? |
| Author: | chris38375 [ Fri Sep 11, 2009 11:01 pm ] |
they still make johnny 4 play but i think he has a 2 barrel |
| Author: | davehix [ Fri Sep 11, 2009 11:44 pm ] |
homemade made it myself. |
| Author: | Baddvw [ Sat Sep 12, 2009 8:03 am ] |
I had a Johnnys 4-play intake on my old buggy with a 650 Holley and it did not do anygood luck for me, I even tried Edlebrocks and still no luck, It was loading up everytime I go up a hill whether u get into it or just riding around. It works great on level ground and takes off like a scaled dog. I have been through all of the float adjustments and jettings to make it work, no good, I rather stick with my dual webers for now |
| Author: | aboone993 [ Sat Sep 12, 2009 10:45 am ] |
A guy I ride with has several of those 2 brrl carbs sitting around off there dirt car and we were wanting to try one since they are just sitting there .We thought about just running the 2 to 4 brrl adapter on a 4-play manifold But I would like to see a picture of the one you made . |
