 Post subject: oil cooler
PostPosted: Sun Aug 30, 2009 7:43 pm
Im relocating my oil cooler, it was inbetween my seats and gas tank etc... So im movin it up into the frame to get more air, my question is does it matter what end is up or down? Meaning the way the oil is flowing. It was sittin vertically before, now will be sloped with the frame. thanks-jayrod
"IT IS WHAT IT IS"
 Post subject: Re: oil cooler
PostPosted: Sun Aug 30, 2009 8:26 pm
most ive ever seen is up an down with the oil lines top and bottom,but it really dont matter jus what fits ur car
PostPosted: Mon Aug 31, 2009 1:17 pm
Fittings come out the sides or top/bottom?
PostPosted: Mon Aug 31, 2009 8:48 pm
they both come out the same side
"IT IS WHAT IT IS"
PostPosted: Mon Aug 31, 2009 11:20 pm
It does not seem to matter to much. I use to mount mine above the gas tank for air flow kept the fittings horizontal and feed the oil in the top like a radiator. Right now mine are flat and under the fuel tank.
PostPosted: Tue Sep 01, 2009 1:00 pm
If the cooler is mounted vertical with side inlets I always try to have the "in" at the bottom and the "out" at the top.
This should keep the cooler full of oil when operational.
That should maximize oil cooling.
