 Post subject: Main bearings Q&A
PostPosted: Tue Jul 28, 2009 8:45 pm
Ive got a Scat catalog and im looking at the main bearings,it say's Type 1 main journal/standard case and then it has the sizes.below that it say's, .20"/.50mm Oversize case.What does oversize case mean.I had a crank turned .20" and the case lineboard.The machinest told me the rods and the mains were cut down .20",so i ordered the bearings that were under the standard case column,but the front and rear bearing dont fit tight,they move side to side a little and i know that is not right.Is there a difference between Chevy journal and VW journal when ordering main bearings for the case.
 Post subject: Re: Main bearings Q&A
PostPosted: Tue Jul 28, 2009 9:53 pm
When you get your case line bored you have to run oversize main bearings to take up for the material that was cut away . You also have to make sure the thrust wasnt cut down also
PostPosted: Wed Jul 29, 2009 9:12 am
Thats exactly what i needed to know,thanks aboone.
PostPosted: Wed Jul 29, 2009 7:53 pm
One more question,VW journals are larger in diameter than Chevy ,right?
PostPosted: Wed Jul 29, 2009 9:32 pm
yes
