It is currently Mon May 04, 2026 11:42 pm
 Post subject: holly carbs..
PostPosted: Mon Jul 27, 2009 12:22 am
I am gettin ready to redo my engine and take it up to a 1915 but I dont have the cash for a set of webbers.But I do have a good 4bbl holley(not sure on cfm atm) and a good 500holly 2bbl. Is there any way to use one of them. I dont mind fabbin parts up eather.
 Post subject: Re: holly carbs..
PostPosted: Fri Jul 31, 2009 7:18 pm
the 2 barrel will work better than the 4,or get u a progressive off of a 2.0 or 2.3 ford motor
PostPosted: Fri Jul 31, 2009 8:36 pm
The Holley 2 bbl or a Weber IDA might be the best choices as they can be adapted for bouncing around off road.
PostPosted: Sat Aug 01, 2009 1:54 am
weber ida are drag racing carbs u must be talking bout IDF webers
PostPosted: Sat Aug 01, 2009 10:07 am
i got a freind that runs a 500 holley like this one on a 2276. i run this motor on my buggy 4th weekend and it run great did not mess up at all.
PostPosted: Sun Aug 02, 2009 2:40 pm
damn dave dont give away all my secrets these guys wont wanna run it any way it does not have a vw approved stamp on it lol
PostPosted: Thu Aug 06, 2009 1:01 pm
We had a Quadrajet off a 350 cheby on a buddys 2l type4 buggy and afte some minor adjustment it ran great,,,so yes if you have the time and knowledge about any carb will work but theres limits to everything,you just have to step out of the box!
PostPosted: Thu Aug 06, 2009 1:11 pm
I run a 2 barrel and it has worked fine for me. The thing that I notice about the 2barrel setup is that you lose throttle response due to the long length of the intake runners. It isn't laggy or anything, just not as crisp as a well tuned dual setup. :)
Aut Viam Invenium Aut Faciam!
