It is currently Mon May 04, 2026 8:49 am
PostPosted: Sat Jul 04, 2009 12:13 pm
I have 2 45's that I plan on running on my new woods motor, but they are not dual's. They are both singles. I don't figure I would have to do much to make them work as a pair. Make sure they both have the same jets, venturis, and so on. I have heard some people say to "fill in" the holes in the throttle blades, and others say not to worry about 'em. I tried to run them as a pair about 10 years ago before I was very carb savy, and had no luck. Then I got webers, and HAD to learn carbs :roll: . Any suggestions?
PostPosted: Wed Jul 08, 2009 6:02 pm
Most Dells that have been converted to run as a single carb have had the accel. jet squirter drilled out. You might have to get a stock set of squirters to put in them. Other than that it should not be an issue.
