It is currently Mon May 04, 2026 11:26 am
 Post subject: Dual 44 IDF jet help
PostPosted: Wed Jun 24, 2009 1:04 am
Need some suggestions on what to change in my jetting. Looks like its running a little rich
Engine specs
2332
110 cam
11 to 1 compression ratio
Ported stock heads with 40 x 35.5 valves
Autocraft ratio rockers (don’t know what ratio)
MSD Distributor
MSD off road ignition
MSD High vibration coil
NGK B6HS Plugs gapped to 40
Dual 44 idf’s with CB upgrade kit
Jetting
F-7 Tubes
130 Mains
160 Air corrections
55 Idles
 Post subject: Re: Dual 44 IDF jet help
PostPosted: Wed Jun 24, 2009 8:20 am
For that size motor your air corrections are a little on the small side. Also the oil on the threads is an Indication that your burning oil and not nessasarly running too rich. Its appears you may have a little of both conditions.
PostPosted: Wed Jun 24, 2009 2:30 pm
I am running 44's with an upgrade kit from CB Performance with F-11 tubes, 65 idles, 145 mains, 200 air, and some backing off on the accelerator pump. I have tried over $400 worth of jets and adjustments and this is the best I can get, I even bought a set of F-7 tubes and it made the motor run like it got a set of IDF 40's (like it is WAY too small) This is a 2276cc with 44x37.5 S/E heads, FK-7 cam, 1.4:1 rockers, all MSD goodies, Champion 810 plugs gapped at .055 inch. You can wipe your finger inside the exhaust pipe and it is not black at all, not even a smudge.
PostPosted: Wed Jun 24, 2009 4:32 pm
looks like its burning pretty good
PostPosted: Wed Jul 01, 2009 2:30 pm
Somtimes it is not as complicated as it may seem. Sounds to me like your float needs adjusted. Your Bowl may be filling up to high. When it comes to off-road the float level is very important. If your bowl is filling up to far you will run very rich no matter what you do to the jets. Are both sides of your engine showing the same signs or is one side worse?
PostPosted: Mon Jul 06, 2009 11:47 pm
The jets I posted were wrong. They were off my old single 44idf.
I just checked the dual 44 idf and they have
55 idles
145 mains
F11 emulsion tubes
200 air
I put new NGK’s in before my last trip and had to pull them when I rolled it. The plugs looked like new after 4-5+ hrs of hard riding.
Also the floats have been set to 15mm suggested by Weber for hard off-road.
PostPosted: Tue Jul 07, 2009 11:23 am
Ok, thats more like what you should have in those carbs. When you say the plugs look like new, are the porcelins still white?
PostPosted: Tue Jul 07, 2009 7:50 pm
They looked brand new, It looked like I just put them in. It was just after the roll so that might have washed them off. It would hardly crank over and was dumping gas out of the exhaust. I’m riding this weekend at Walhonding Hills Campground so I will pull them after that trip and post some pictures.
PostPosted: Wed Jul 08, 2009 11:03 am
Does it always run bad, or just sometimes, like when climbing, or going over rough stuff? Do you still have the choke bodies on them?
PostPosted: Wed Jul 08, 2009 11:34 am
Ok, Keep an eye on them because setting the float to 15mm has leaned out the carbs. White plugs = lean condition and is not good. Rejetting may be required.
PostPosted: Wed Jul 08, 2009 5:40 pm
Try the floats at 12.
PostPosted: Tue Jul 14, 2009 11:34 pm
Here they are after my last trip. 110 fuel, trail riding and a few small hills, about 6hrs total riding time.
What do you think?
PostPosted: Tue Jul 14, 2009 11:48 pm
looks fairly good ,,maybe a little rich,if so you run on ur idle jets probaly 75% of the time,u might need to go down 2.5 on your idles jus to try it
PostPosted: Wed Jul 15, 2009 8:12 am
They look good to me. You are running pump fuel, right?
PostPosted: Wed Jul 15, 2009 8:54 am
looks like #2 is lean not bad
PostPosted: Wed Jul 15, 2009 9:00 am
Those are running just fine. Now leave the the carbs alone and ride lol. :mrgreen:
PostPosted: Wed Jul 15, 2009 11:42 am
I'm running 110 with 11 to 1 compression
PostPosted: Thu Jul 16, 2009 3:10 pm
Looks damn close to me. #2 is a bit lean, fatten it up some.
PostPosted: Thu Jul 16, 2009 3:19 pm
If your running race fuel, it is a lot harder to read the plugs. The inside of my exhaust is white when I finish a race, but its not running lean. I just played with jets, and when we dynoed it, we could monitor the egt and they were all actually kinda low. i wanna say around 1100 degrees or so. But if you look at the plugs, you would say its lean.
