 Post subject: empi carbs
PostPosted: Thu Apr 30, 2009 9:00 pm
any1 runnin duel empis??
 Post subject: Re: empi carbs
PostPosted: Thu Apr 30, 2009 9:45 pm
A buddy of mine has a set of 40's on his 2165.Had them for over a year without any problems.I might try a set on my sons 2054 if i can't find a set of webers used.
PostPosted: Fri May 01, 2009 11:06 am
im thinking of tryin them. was wanting webers but a friend is tryn 2 talk me into the empis he says he loves them and they r bout 300 dollars cheaper than the webers.but iv heard bad things bout them was wonderin if empi had corrected the old problems
PostPosted: Fri May 01, 2009 11:53 am
Mark Harney did a good write up on the Empi carbs on thesamba.com. He showed all the problems and how to correct them.
Aut Viam Invenium Aut Faciam!
PostPosted: Fri May 01, 2009 12:14 pm
If you are willing to work on them to get them straightened out it "might" be worth it.
Me personally......I would never buy a set. Long term trouble.
PostPosted: Fri May 01, 2009 5:45 pm
good luck with the empis,a buddy of mine got some ,,never could get them right,,i tryed working on them with no luck,,spend the extra money and buy weber,or u can always find some used delortos at a good price
PostPosted: Fri May 15, 2009 4:28 pm
put the dual empis on yesterday afternoon without any problems and only minimum work.
had 2 go up to 55 idle jets and couple of turns of the air mixture screws and it was perfect. feels like an entirely different enine.. very very encouraging after all the horror stories ive heard. lets just hope it stays this good...lol... :wink:
PostPosted: Fri May 15, 2009 4:58 pm
PostPosted: Mon May 18, 2009 9:03 am
Jake Raby swears that with a little bit of set-up they are just fine. He has the reputation of being one the the pickiest v-dub guys in the business. i will say, his stuff works though.
http://www.aircooledtechnology.com/store/
PostPosted: Mon May 18, 2009 12:17 pm
I have not used the EMPI brand however everything I have heard about them was not good. Its a crap shoot to get a good set.
PostPosted: Mon May 18, 2009 5:20 pm
Looks good just oil the filters & grease tops & bottems.
PostPosted: Mon May 18, 2009 8:42 pm
I'm glad they worked out for you, Good job!
PostPosted: Mon May 18, 2009 10:38 pm
moondog wrote:
Glad they are working for ya. I would however get rid of those filters. You are asking for trouble. Get a set of 6" tall uni filters and cast aluminum tops and bottoms from CB Performance. Dirt will kill the carbs not to mention the engine..
