It is currently Mon May 04, 2026 3:29 pm
 Post subject: Bobcat Air Cleaner
PostPosted: Thu Jun 07, 2007 3:43 am
I was bitching to my buddy, who works for a Bobcat service company, about my clogged jet problem. Well he stopped over today and gave me this air cleaner for free. He said it should work because bobcats are constantly in dusty conditions.
Do you think this would be worth my time hooking up for an air cleaner?
It looks a little small compared to the ones I saw at D&K.
Brad
PostPosted: Thu Jun 07, 2007 4:52 am
I don't see why that would not work. What is the displacement of the engine in the Bobcat?
PostPosted: Thu Jun 07, 2007 1:15 pm
Those centrifical air cleaners are the best you can buy for offroad. Very good score!!!
PostPosted: Thu Jun 07, 2007 3:16 pm
[quote='Roy'] What is the displacement of the engine in the Bobcat?[/quote]
I called him and he said 4 cylinder, 98 cubic inch Ford.
PostPosted: Thu Jun 07, 2007 3:20 pm
You can't bitch about FREE. 98ci. that's aproximately 1600cc.
PostPosted: Thu Jun 07, 2007 5:28 pm
I need one of those, great find!
PostPosted: Fri Jun 08, 2007 10:24 am
[quote='hillaholic'][quote='Roy'] What is the displacement of the engine in the Bobcat?[/quote]
I called him and he said 4 cylinder, 98 cubic inch Ford.[/quote]
I dunno, I don't think that industrial engine turns the RPM that a 1600 cc woods buggy engine sees.
Bigger version would be the schnitz though........ 8)
PostPosted: Fri Jun 08, 2007 2:08 pm
what carbs (or carb) are you running
- Sigmund Freud
- Antonio Meloni
PostPosted: Sat Jun 09, 2007 4:40 pm
[quote='plumberbill']what carbs (or carb) are you running[/quote]
1915 with Dual 44 IDF
PostPosted: Sun Jun 10, 2007 12:18 pm
You would need at least two of those to handel the CFM requirement for that motor and carbs to give you the best results
PostPosted: Sun Jun 10, 2007 2:22 pm
Hill Climber
Brad, thats what I am going to go to. I wish I would have had it at D&K. Would have been a great test. My carbs where full of dust. This is a pic of the adapter I made to plum my airbox into. I saw these on the score cars when I went to Lauglin last winter. I would not think a 3 inch out let would be enough but thats what they were running and it worked.
PostPosted: Sun Jul 22, 2007 2:08 pm
IF that bobcat filter does not work out for you, ask your buddy if he deals with the big diesel air compressors, they use the same style filter, just larger..the more CFM the compressor..usually the bigger the filter..
did he hook you up with the inner filter? (slides up inside the paper element)
And lots of bob cat rental places also rent out those compressors also..
Cale
Its not how big you build it, its how you build it big.
