| distributors?? http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=6131 |
| Author: | bradley59dzl [ Mon Mar 23, 2009 11:01 pm ] |
| Post subject: | distributors?? |
whats everyone running and whats your thoughts... points, msd, petronix??? i was thinking of running compu -fire dis-ix just trying to get some thoughts.... |
| Author: | purplerail [ Tue Mar 24, 2009 7:31 am ] |
| Post subject: | Re: distributors?? |
i use a 050 with pertronix and soon msd |
| Author: | rockrockets1 [ Tue Mar 24, 2009 8:29 am ] |
compufire is no good to me left me stranded Petronix is what I allways run never had a problem |
| Author: | Roy [ Tue Mar 24, 2009 8:40 am ] |
You can't go wrong with a Pertronics. I liked them so much I even installed a Pertronics in my boat motor. |
| Author: | Kyle [ Wed Mar 25, 2009 9:00 am ] |
Pertronix in my buggy, MSD Blaster2 High Vibration coil, MSD 6AL Ignition, 009 Dissy. Supposedly if you run the MSD coil with the pertronix module, you are supposed to run a resistor to prevent it from burning up, I have never ran one and ran this setup for a year, but on a friends we had to install one or it would fry modules. |
| Author: | Roy [ Wed Mar 25, 2009 2:04 pm ] |
It depends which MSD coil you use. |
| Author: | rockrockets1 [ Wed Mar 25, 2009 2:32 pm ] |
I ran mine with a bosch blue coil |
| Author: | bradley59dzl [ Wed Mar 25, 2009 2:46 pm ] |
yea dif. ohms resistance |
| Author: | chris38375 [ Wed Mar 25, 2009 2:56 pm ] |
hei,,out of a small block chevy,,plug and go coil is on top of the cap,,,,performance distrubitors,,memphis tn |
| Author: | Firebug [ Wed Mar 25, 2009 3:03 pm ] |
I got robbed,,no distributor,,,but I got 6 coils |
| Author: | redrail1915 [ Wed Mar 25, 2009 6:27 pm ] |
chris38375 wrote: hei,,out of a small block chevy,,plug and go coil is on top of the cap,,,,performance distrubitors,,memphis tn what he said
| Author: | bradley59dzl [ Wed Mar 25, 2009 6:29 pm ] |
chris38375 wrote: hei,,out of a small block chevy,,plug and go coil is on top of the cap,,,,performance distrubitors,,memphis tn whats the dif. in the street/strip to the race.???? |
| Author: | redrail1915 [ Wed Mar 25, 2009 6:51 pm ] |
coil and timing curve i think |
| Author: | khaney01 [ Wed Mar 25, 2009 7:01 pm ] |
I've got one out of a 4 cylinder Mitsubishi in mine. Shorten the housing and the shaft, drill it for the VW gear and drop it in. My brother Rick has run one for 14 years without the first problem. My brother Eddie ran one for 7 years until the module went out last summer because the regulator in his alternator went out. I've run mine for 5 years so far with no problems. |
| Author: | chris38375 [ Wed Mar 25, 2009 9:37 pm ] |
bradley59dzl wrote: chris38375 wrote: hei,,out of a small block chevy,,plug and go coil is on top of the cap,,,,performance distrubitors,,memphis tn whats the dif. in the street/strip to the race.???? i think it is the curve,they put diferent size springs in the dist.and a better coil |
| Author: | DixieBoysRacing [ Thu Mar 26, 2009 12:55 am ] |
I like a standard 009 with ignighter? Had no problems... |
| Author: | Kyle [ Fri Mar 27, 2009 10:44 pm ] |
Roy I believe its with any of the blaster series. They put out around 17amps I believe and the pertronix can only handle 7 I think? Its a low low number compared to the output of the MSD. |
| Author: | volksdude2007 [ Sun Mar 29, 2009 9:36 pm ] |
i run an 009 with bosch points havnt changed them in about 2 years or so still running good |
| Author: | afterburnt [ Sun Apr 05, 2009 11:48 am ] |
I used to run the Pertronix ignighter with a 09 distributer, and i was having a problem, i thought that my carborators were running rich. It turns out the ignition system wasn't hot enough to fire all of the fuel. I switched to the MSD 6AL box. with the MSD distribuator and MSD coil. what a difference. I got twice the power, and its burning the fuel real clean. |
| Author: | Stevo [ Mon Apr 06, 2009 7:47 am ] |
Firebug wrote: I got robbed,,no distributor,,,but I got 6 coils Me too! no dist just a coil with four wires must be magic. I ran pertronics for years in a 009 and loved it. |
| Author: | bradley59dzl [ Mon Aug 31, 2009 12:21 pm ] |
update... i finally spent the money and switched to full msd.. |
| Author: | afterburnt [ Mon Aug 31, 2009 5:04 pm ] |
let us know how you like it |
| Author: | bradley59dzl [ Wed Sep 02, 2009 12:11 am ] |
afterburnt wrote: let us know how you like it i love it.. starts easier,runs much better, smoother and quicker throttle respnose. Next some fuel injection |
