 Post subject: good or not
PostPosted: Fri Mar 20, 2009 7:58 pm
This good or not 69 MM VOLKSRACER FORGED COUNTERWEIGHTED CRANKSHAFT
I was look at this one 8)
 Post subject: Re: good or not
PostPosted: Fri Mar 20, 2009 10:10 pm
Its fine if all you want is a stock stroke motor. With over the counter 94mm Pistons and cylinders the biggest motor you can build is a 1915.
PostPosted: Sat Mar 21, 2009 8:18 am
Trow a few extra bucks in and get you a stroker .You will be glad you did trust me :lol:
PostPosted: Sat Mar 21, 2009 8:01 pm
Like RR said,buy a strocker crank. I have built a few motors with the 74 mm crank from CB Performance and it was only $179. It is easier to set your compression ratio with a strocker crank,you just buy barrel shims to adjust it. JMO
PostPosted: Sat Mar 21, 2009 9:01 pm
Always build the LARGEST motor within reason. My type 1 is 2643cc. Remember "There is no replacement for displacement'
PostPosted: Sat Mar 21, 2009 9:09 pm
Thank guy but I have 3 rid and got lot of money in it that i can not get back so am run it to the gave that is keep me from the big crank
