It is currently Mon May 04, 2026 2:05 pm
 Post subject: straight cut cam gears
PostPosted: Tue Feb 10, 2009 10:32 pm
whats the benefit? do i have to run them with dry sump setup? just have no idea what they are for.
"Lets go get stupid"
PostPosted: Tue Feb 10, 2009 10:53 pm
straight cut teeth creates less drag for increased horsepower. This design reduces thrust load on the cam bearings preventing premature failure....they will also b noisy
PostPosted: Tue Feb 10, 2009 11:05 pm
I run them, but you do not have to have them to run dry sump, but it is worth it though, it does not matter to me how noisy it is, I can't hear the damn thing anyways when I floor it! :mrgreen:
PostPosted: Wed Feb 11, 2009 2:13 am
Quote from geneberg
An absolute must for all applications to stop cam bearing thrust wear when triple or Chevy type springs are used. They create so much load on the camshaft that the helix type gear is loaded all to one side and prematurely wears out the thrust surface of the cam bearing. In fact, on our race engine it wore out the cam bearing in just one race day. (POTL) We often resize these to fit properly and reject the bad ones. Made in the USA.
http://www.geneberg.com/cat.php?cPath=6_180_2775
PostPosted: Wed Feb 11, 2009 11:13 am
Thanks guys!
Kyle
PostPosted: Wed Feb 11, 2009 3:25 pm
Just another note on the dry sump Oil pump setup. Make sure you use Button head allens on the cam gear to provide enough clearence for the back of the pump.
PostPosted: Wed Feb 11, 2009 5:47 pm
Thx ody!
