| Blown oil galley plug http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=5231 |
| Author: | Buckmaster [ Wed Dec 03, 2008 10:02 pm ] |
| Post subject: | Blown oil galley plug |
A freinds motor blew 1 of the larger oil galley plugs out the back of the case,has anyone seen this and what size drill bit and tap would i need to fix it. |
| Author: | Baddvw [ Thu Dec 04, 2008 9:58 am ] |
| Post subject: | Re: Blown oil galley plug |
Here is some info on you request, but I don't know what size you will need depending on how large the hole is. NPT National Pipe Thread Tap size. Threads per inch. Drill size. 1/8 - 27 - 11/32 1/4 - 18 - 7/16 3/8 - 18 - 19/32 1/2 - 14 - 23/32 3/4 - 14 - 15/16 1 - 11-1/2 - 1-5/32 |
| Author: | turboblue [ Thu Dec 04, 2008 12:04 pm ] |
Best if you use a tapered reamer along with that tap drill. 3/8" NPT is the most common plug for the bigger galley. Here is a good site for some pointers on galley plugs. http://www.huelsmann.us/bugman/FilterTech.html |
| Author: | Buckmaster [ Thu Dec 04, 2008 6:56 pm ] |
That site and chart is a big help,thanks alot Gary. |
