| Can you Drill mexico case 4 full flow?????? http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=5099 |
| Author: | travisdunebuggy [ Sat Nov 15, 2008 12:50 pm ] |
| Post subject: | Can you Drill mexico case 4 full flow?????? |
Is this it ive got a as-41 that has been done like that on my buggy that 2276 case isnt just wandering if ther is any differance between the 2 so i can make the mexico case full flow???? and what i need to do besides just drilln it if any thing ????? |
| Author: | vwtravis [ Sat Nov 15, 2008 4:31 pm ] |
| Post subject: | Re: Can you Drill mexico case 4 full flow?????? |
Thats the right port it needs drilled to 37/64 and taped to 3/8 pipe. The top of the port is thin I had to weld the top of mine to keep it from cracking. The hole needs drilled off set down a little. I like to tap the port going from the oil pump to the one you drilled 1/4 and plug so you dont got to plug the pump. |
