Bent rod!!!(2276)
http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=5081
Author:  travisdunebuggy [ Wed Nov 12, 2008 6:07 pm ]
Post subject:  Bent rod!!!(2276)
Hey guys i just traded some stuff 4 a 2276 in a box every thing looks good but one of the rods its twisted a little and ive never clearnced rods b4 can i get an odd rod and balance it with the others or should i just get a whole nother set :? oh yea it has dropped a valve thats the reson 4 the bent rod!! :|
Author:  turboblue [ Wed Nov 12, 2008 6:11 pm ]
Post subject:  Re: Bent rod!!!(2276)
What kind of rod?
Author:  travisdunebuggy [ Wed Nov 12, 2008 8:46 pm ]
:? Well they look stock dont realy know
Author:  FOX SHOX [ Wed Nov 12, 2008 8:48 pm ]
post some pics. Thanks Dave T
Author:  travisdunebuggy [ Wed Nov 12, 2008 11:57 pm ]
I cant get photobucket 2 load my pics it keeps sayn err on page????????but i think there just stock rods :cry:
Author:  travisdunebuggy [ Thu Nov 13, 2008 11:09 pm ]
Image ok i think this is it!!! :shock:
Author:  Roy [ Fri Nov 14, 2008 5:15 am ]
That's stock for sure. You can replace just the one rod and balance it to match the other three. You would definitely want to have the other three checked and rebuilt while you are at it. In my opinion, if you are going to go to all that trouble, just get another set already done. (unless you do all your own work)
Author:  turboblue [ Fri Nov 14, 2008 12:17 pm ]
I think I'd do an upgrade for that engine.
Either these:
http://www.cbperformance.com/catalog.asp?ProductID=1179
or these are an inexpensive alternate to stock rods.
http://www.cbperformance.com/catalog.asp?ProductID=1513
Author:  travisdunebuggy [ Fri Nov 14, 2008 5:24 pm ]
Yea i[*] like the second ones but i'll prob go back with stock the motor was only supposed to have about 4 or 5 rides tha wrist pin end still look new !! :shock: he only had single valvesprings it must have slapped the piston cause it snapped it right at the valve the rod isnt bent real bad so im hopen its not hurt!! :mrgreen: Image
Author:  turboblue [ Fri Nov 14, 2008 5:27 pm ]
Have the crank checked.
Any episode that would twist a rod like that can't be good on the crankshaft.
Author:  travisdunebuggy [ Fri Nov 14, 2008 5:33 pm ]
who and where would i go to get it checked what would be some obvios thing i could look for i spun the rod around the crank it seemed tight still the bearn looked almost brand new !! :mrgreen:
Author:  turboblue [ Fri Nov 14, 2008 6:31 pm ]
Any automotive machine shop should be able to check it for you.
Need to make sure it isn't bent.
Sometimes a spun rod bearing will bend one.
Same thing might apply to this situation.
I would check it for you if you were closer......... :wink:
Author:  travisdunebuggy [ Fri Nov 14, 2008 6:44 pm ]
I have acess to a garage what do i need to do to make suer it isnt bent b4 i go buying parts!! :mrgreen:
Author:  turboblue [ Fri Nov 14, 2008 6:51 pm ]
By garage you mean a automotive repair shop or automotive machine shop?
An automotive machine shop should be able to set it up in V blocks and put an indicator on the journals to tell if it's straight.....
Author:  travisdunebuggy [ Sat Nov 15, 2008 12:18 am ]
well its not all that :oops: theres a machine shop i can carry it to what just tell em what happened an let em check it 8)
