It is currently Tue May 05, 2026 1:16 am
 Post subject: jet doctors
PostPosted: Tue Jul 08, 2008 7:26 pm
does anyone have jet doctors in their webers? do they work?
 Post subject: Re: jet doctors
PostPosted: Tue Jul 08, 2008 8:28 pm
Everyone that I know that run webers run the jet doctors--they tell me that they help alot--I have mine laying on the counter getting ready to install-waiting on foam filters to show up!
Mark
High speed
Low drag
Teflon coated
And ready for action!
PostPosted: Wed Jul 09, 2008 1:32 am
They work for me!!, best money spent on carb upgrade.
PostPosted: Wed Jul 09, 2008 9:07 am
When I was running Webers the jet doctors helped however the CB performance 6" dual stage foam filters made more of a difference. Also using CBs cast aluminum tops and bottoms plates is a must. The cheapo chrome tins allow a lot of dirt in.
PostPosted: Wed Jul 09, 2008 10:46 am
i put the jet doc. & the cb sand seal breather kit on at the same time. dont no witch one help the most but it fixed the problem.
kenny ( AKA D.O.G. )
PostPosted: Wed Jul 09, 2008 5:54 pm
The jet doctors are worth every penny. :mrgreen:
PostPosted: Thu Jul 10, 2008 7:13 pm
i run them 2,they designed them for dual carbs in a full body car because it is so hard to get to the jets,I LOVE THEM NEVER HAVE A PROBLEM
PostPosted: Fri Jul 11, 2008 10:02 pm
they worked 4 me also
PostPosted: Sat Jul 12, 2008 7:38 pm
im sold gonna order a set every bit can help
PostPosted: Sat Oct 18, 2008 9:23 pm
I hate to be an ass, but all the jet doctors do is move the idle jets air supply up high enough that all the DIRT that is getting THROUGH your filters is less likely to plug the idle jets. A good paper (NOT a K & N) air cleaner in a housing that seals will fix the problem. Keep the dirt out of the motor and the idle jets will not plug.
When in doubt, Hold it to the floor and hope for the best!
PostPosted: Sun Oct 19, 2008 1:52 am
dont nobody i know run a piece of junk paper filter,and a jet doctor is made to do like a delorto and get its air from a little higher than stock position,SAY NO TO A PAPER FILTER ,THEY ARE JUNK
PostPosted: Sun Oct 19, 2008 10:09 pm
I am sure everyone has seen this: http://www.duramax-diesel.com/spicer/index.htm
I don't believe everything I read on the Internet either. So if you look at engines that are designed to run in hostile environments, i.e. earth moving equipment, mining equipment etc. Most if not all run some variant of the Donaldson Cyclo-pac set up. Also a quick glance at the million dollar trophy trucks that race in the desert and have engines that cost more than my buggy and the house it is parked in, also use this same set up. I am not trying to re-invent the wheel, or start a flame war. If you like jet doctors run them. The point I was trying to make is they solve a symptom not the problem. I used UNI foam filters in the CB cast aluminum housings and they were an improvement over the exposed paper filter until water was added to the mix. The dirt was washed straight through them. This is easily verified when you remove the elements to clean them, The top of the carbs under the air filters will be covered in dirt.
So the opinions I have expressed are my own, right or wrong. The only fact in my observations with my buggy is after switching to the Donaldson set up two years ago I haven't pulled the idle jets a single time, and I don't have jet doctors. So your results may be different, In fact no one I know except me runs paper elements either they think my set up is ugly. So I get to enjoy a cool beverage while they stop to blow out their idle jets. LOL
