 Post subject: 1915 question
PostPosted: Thu Sep 25, 2008 10:41 pm
what is a good cam, heads and rocker setup for 1915?
 Post subject: Re: 1915 question
PostPosted: Thu Sep 25, 2008 11:19 pm
Most woods riders and hill climbers use a Engle W-110 or something similar for the cam and 1.25 rockers. As for heads I think a set of CB 044's usually work very well.
PostPosted: Fri Sep 26, 2008 11:27 am
Ditto
Single 40/44 IDF properly tuned, TriMill exhaust, 9-9.5 compression and that little engine will rock....... :D
PostPosted: Mon Sep 29, 2008 7:51 am
Another great camshaft for a 1915 is the VZ-15. This works great if you want to use the stock rocker arms. Very good all around camshaft and you don't have to spend the money on rocker arms.
PostPosted: Wed Oct 01, 2008 3:13 pm
What is a good rocker arm manufacuter? Afforbality wise and quality wise?
PostPosted: Wed Oct 01, 2008 3:41 pm
CB Performance is tough to beat.
PostPosted: Wed Oct 01, 2008 4:02 pm
As for the heads what intake and exhaust port size? Would 40mm Intake X 35.5mm Exhaust be a good head to run wtih this setup?
PostPosted: Wed Oct 01, 2008 5:11 pm
i have a set of 1.25 autocraft rockers i will sell ya,mofoco makes a really good head to
PostPosted: Wed Oct 01, 2008 5:26 pm
Those valves will work well for a lower RPM motor like in the woods. Especially with chamber work and a good port and polish. If your looking for a high RPM street screamer then go with a 44x37.5 valved head.
