 Post subject: Lets Talk Nitrous
PostPosted: Sat Sep 13, 2008 12:26 am
any1 like to share any experience,pics,Horror stories. I'm finishing up my nitrous setup this week. I'll post some pics
Every man loves a set of TWINS especially sitting on a dragster
 Post subject: Re: Lets Talk Nitrous
PostPosted: Sat Sep 13, 2008 8:40 am
PostPosted: Tue Sep 16, 2008 10:46 pm
Make sure it gets plenty of fuel (big fuel pump lines ect.) most story's begin here. Most kits recommend 5-7 psi you should check it engaged. I burnt 7 pistons on my 340 because a week fuel pump. If your kit is used be sure to check the solenoids rebuild kits are available. Hold on its a blast :lol:
You still running a turbo?
Travis
PostPosted: Fri Sep 19, 2008 5:30 am
yeah still a turbo. my pumps good for 107 gpm at 7 psi and i went fat on the fuel side so i hope to be ok.
PostPosted: Sun Sep 21, 2008 10:31 pm
That sh-- is like a bad drug habit :shock:
I LOVE IT 8)
PostPosted: Mon Sep 22, 2008 1:57 pm
well this was my first weekend with the nitrous. No real major problems.We weren't there an hour and i caught a branch and bent a push rob tube and rod. and while we were driving back some how my purge silenoid got a short and burned up the coil. no big deal though. its defiantly different. I found that i can even use it for in the woods more than i originally thought.It definitely aids the boost at low rpms. I do agree with rocket its definitely addicting. All power adders are addicting all in all.
PostPosted: Tue Sep 23, 2008 8:36 pm
some pics of setup
PostPosted: Tue Sep 23, 2008 9:38 pm
That looks awesome!! Ya better really hold on now!! You think that turbo gave you extra power? You aint seen nothin yet!! lol. Great job on the setup.
What size motor you runnin?
-Dakotah
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Wed Sep 24, 2008 5:52 am
just a 1915. i forgot to mention it breaks the clutch in 4th geer
PostPosted: Thu Sep 25, 2008 4:33 pm
Oh thats kool. Well I bet that is one WICKED 1915!!
-Dakotah
-Dakotah/koko
PostPosted: Fri Sep 26, 2008 6:53 pm
I don't want to bust anyones balls but that setup is going to hurt a lot of parts due to the fact that the fuel pump isn't big enough to supply enough fuel under boost.when using nitrous in a direct port set-up with a turbo you need a fuel pump that will not only make enough pressure to supply the nitrous(usually 6-8 psi)but also overcome the boost pressure you are running.Lets say you are running 10 psi boost and your nitrous is set at 7psi you would need a pump capable of making AT LEAST 17 psi but more like 20 or the boost pressure will push the fuel right back up the nozzles,the engine will go VERY lean and we all know what comes next.To simplify this you can place 1 nozzle before the turbo then you don't have the boost pressure to overcome.Again I'm not trying to put your stuff down I just don't want to see anyone burn there stuff up because of insufficient fuel supply.
PostPosted: Sat Sep 27, 2008 4:23 pm
Aaron has a very good point!!!
PostPosted: Sun Sep 28, 2008 4:30 am
Some of you guys might not know Aaron,But you can take his info to the bank! Him and his dad have ran more vw a/c turbo engines than most of ya's have seen. lol You name it I'm sure they try'd it twice ! :wink:
PostPosted: Sun Sep 28, 2008 9:04 pm
It will also cool the turbo down too!
PostPosted: Mon Sep 29, 2008 2:13 am
what if i was to run the nitrous on like 30# unragulated and add a regulator for my carb and set it at my normal setting
PostPosted: Mon Sep 29, 2008 7:43 pm
why all the negativity :) it works , didnt blow up :):)
so lets have fun with it :)
PostPosted: Mon Sep 29, 2008 8:45 pm
No negativity brother! Just trying to save a costly rebuild.
PostPosted: Tue Sep 30, 2008 3:18 am
Just trying to save him some major headaches and heartaches, I played with it(nos) for awhile and wish someone would have gave me better info! melted and trashed a lot of peaces
PostPosted: Tue Sep 30, 2008 4:43 am
so what are your thoughts on this
PostPosted: Tue Sep 30, 2008 10:04 am
Personally, I would run regulators on both fuel and nitrous.
PostPosted: Tue Sep 30, 2008 9:13 pm
it's a realy bad feeling when that sucker cough and the pistons are in the oil pan :cry:
and trust me you realy don't want them there :shock:
tell um DVS1 there ain't much us old guys ain't tried 8)
