It is currently Tue May 05, 2026 2:29 am
 Post subject: Dry sump
PostPosted: Sat May 05, 2007 9:59 pm
Roy or anybody with a CB Dry sump. I purchased this sump and power pulley from CB, I put the pulley on today and it hits the sump. Did any of you guy's have this same problem? If so what did you do to fix it?
Thanks, Dave
PostPosted: Sat May 05, 2007 11:25 pm
I had the same problem. I ended up machining the upper flange area of the pump cover and the backside of the pulley until they cleared each other. Makes it a pain to change the belt, but I've had it that way for 2 years now, with no problem.
I just found out while Tim was helping me build my wife's 2276 a couple months ago that there is actually ANOTHER size pulley designed for those dry sump pumps that is an even smaller diameter. Thats what I put on her motor. The people at CB should of told you about that, just like they should've told me!
I believe using the larger power pulley and machining the parts for clearance is actually better, though, if you wanna go thru the trouble. The larger pulley should turn the fan and alternator a little faster. I just used a 3" disc on an angle grinder and CAREFULLY machined the upper "Indent" at the top of the pump cover to where it was about 1/8" thick. Then I grinded off the back edge of the pulley until there was enough clearance. Kinda sucked taking a grinder to those brand new parts, though :evil:. But it worked fine!
I aint sayin' you SHOULD do this, I'm just tellin' what I did because I didnt want to wait for a new pulley. Already had everything else and wanted to hear it run! :lol:
PostPosted: Sat May 05, 2007 11:40 pm
For as much expensive stuff that I had to grind and cut just to get the motor together, that don't bother me. I had thought of that, but was concerned about the pulley being off balance. Won't that screw up the harmonics of the motor? Or being that is light (aluminum) it won't make a noticable difference?
Thanks for the input kybuggy1, Dave
PostPosted: Sun May 06, 2007 5:05 am
http://www.cbperformance.com/catalog.asp?ProductID=253
I used this when I assembled mine.
Roy
PostPosted: Sun May 06, 2007 7:22 am
I used a differant type of shim kit when i installed my pulley.It was two spacers about 1/8",one for alt and one for the crank.Then i machined the back of my power pulley.I did not touch my oil pump.So i can replace my belt without any problems.
PostPosted: Sun May 06, 2007 10:28 am
[quote='Roy']http://www.cbperformance.com/catalog.asp?ProductID=253
Roy[/quote]
Thanks Roy, They should have told me that I would need that kit.
PostPosted: Sun May 06, 2007 5:02 pm
Yeah, know that you mention the shim kit I remember someone telling me about it. Didnt want to wait on that either! :twisted:
PostPosted: Sun May 06, 2007 9:26 pm
Believe me brother, I'm getting extremely impatient too.
PostPosted: Mon May 07, 2007 7:28 pm
If you guys are using power pulleys you are slowing the fan/charging system down nearly 20%.
I have used T-3 generator pulleys up top in the past to speed the fan back up.
They are smaller on the OD and will get the drive/driven pulley ratio closer to what it is stock.
Now I use these on dry sump engines:
No fuss, no muss, plenty of air and charging.
PostPosted: Tue May 08, 2007 1:46 am
Gary,That set up looks Good,Did you build it ? How much $$ ? Mudd
PostPosted: Tue May 08, 2007 11:13 am
[quote='mudd mutt']Gary,That set up looks Good,Did you build it ? How much $$ ? Mudd[/quote]
BMD sells that kit, I am one of their dealers.
I get $240 for the kit, I cover the shipping in the lower 48.
I supply the sand seal too.
They sell them for $210 on their website but you have to pay the shipping and they don't come with the sand seal.
About a wash actually....... 8)
It's the schnitz for dry sump systems..........
Only thing you have to do is change the two rear
PostPosted: Tue May 08, 2007 3:27 pm
Does it clear the CB Performance pump? I know you have to be familiar with that pump.
If it does clear, is the seal a knock in seal or machine in?
Thanks,
Roy
PostPosted: Tue May 08, 2007 4:56 pm
Yeah it clears fine Roy.
The seal is a bolt in version.
They will machine the steel sleeve to any size seal you choose but the default size is 1.770".
I like these kits over spacing out and machining the backside of a power pulley.
I've had to do that before these serpentine systems came along.
This is a power pulley and a CB dry sump pump.
It clears by a whisker after I put in a space and machined the backside.
Little close but it did clear.
I hate to put more than 1 spacer in as the drive area gets shorter and less engagement of the pulley woodruff key.
Then you have to worry about getting the fan speed back to where it needs to be.
CB's little pulley is just too small to suit me.
I tractor around at low speed in the woods, I'd imagine my stuff would start cooking in short order...... :eek:
PostPosted: Tue May 15, 2007 8:51 pm
I just got my new pulley system from Gary at Davis Racing. (Turboblue)
I must say that this stuff is top quality stuff and I love it. I am very happy with it. The most important thing of all is now my fan speed is back to where it needs to be. It has always bothered me that I was running an underdrive pulley. Anyone running a dry sump pump should look into this product.Image
PostPosted: Wed May 16, 2007 12:23 pm
Lookin' good Roy.
Thanks for the plug....... :mrgreen:
PostPosted: Wed May 16, 2007 12:41 pm
That is the shiznit!! Gotta have one. No more belt yelling at me when I kick the throttle! (Probably gotta have two, if mama sees it on mine, she'll want one on hers! :roll: )
How about a 2fer, Gary!! :lol:
PostPosted: Wed May 16, 2007 3:12 pm
[quote='kybuggy1']That is the shiznit!! Gotta have one. No more belt yelling at me when I kick the throttle! (Probably gotta have two, if mama sees it on mine, she'll want one on hers! :roll: )
Larry[/quote]
Sure, I'll hook you up....... 8)
I'll PM you my number...........
PostPosted: Wed May 16, 2007 5:04 pm
Sounds good. I'll get back to you after Mem. Day gets done draining my play money and I make some more!
PostPosted: Fri May 18, 2007 12:41 pm
Forgot to tell you guys using the BMD system to put a drop of locktite on the top pulley nut.
Just a little insurance.......... 8)
PostPosted: Sun May 20, 2007 7:50 am
I use lots of Locktite when I work on my buggy. I hate things coming loose.
cron
