| msd problem http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=442 |
| Author: | plumberbill [ Wed May 09, 2007 10:50 am ] |
| Post subject: | msd problem |
running a msd 6a and msd dizzy.when i turn off the ign. the motor runs 3 to 5 sec. after shut down. this only happens when the motor is warmed up. msd had me put a diode on the wire to the dummy light and tee a ballest resistor in line with the switched power to the msd. still have the same problem. |
| Author: | Roy [ Wed May 09, 2007 11:00 am ] |
| Post subject: | |
The only thing I can think of is the diode in the charging light circuit is installed backwards. I feel the problem lies in this area. I can't see where using a resistor to the main power for the MSD box would do anything. Actually I think it would hurt you. Try pulling your fan belt off and firing the motor up for a second and turn it off. See if it still does it with the belt removed. Roy |
| Author: | plumberbill [ Wed May 09, 2007 11:16 am ] |
| Post subject: | |
diode is installed with the silver ring towards the alt. per msd ign. switch has been replaced |
| Author: | billykissell [ Wed May 09, 2007 11:24 am ] |
| Post subject: | |
try a fuel shut-off solenoid? i know this is fixing the symptom, but a good safety feature to boot. |
| Author: | Odyknuck [ Wed May 09, 2007 12:34 pm ] |
| Post subject: | |
A fuel shut off solinoid will not help this problem. You still have float bowls full of gas. |
| Author: | kybuggy1 [ Wed May 09, 2007 1:06 pm ] |
| Post subject: | Re: msd problem |
[quote='plumberbill']running a msd 6a and msd dizzy.when i turn off the ign. the motor runs 3 to 5 sec. after shut down. this only happens when the motor is warmed up. msd had me put a diode on the wire to the dummy light and tee a ballest resistor in line with the switched power to the msd. still have the same problem.[/quote] Do you have any accesories or lights or anything wired to your alternator? In other words, did you used it as a place to pick up 12 volts for something? If |
| Author: | Odyknuck [ Wed May 09, 2007 3:02 pm ] |
| Post subject: | |
MSDs logic on the ballast resistence was to take the power to ground when it was turned off. Its in parrellel not in series with the power feed. |
| Author: | gustograber [ Wed May 09, 2007 5:21 pm ] |
| Post subject: | |
i`ve seen that happen when the fan on the oil cooler was hooked to the coil so it wood run whenever the key was on. |
| Author: | DVS1 [ Thu May 10, 2007 12:45 am ] |
| Post subject: | |
Like Gusto said. But I can tell you from personal experience, I had everything on one wire ign,fuel and fan for the oil cooler. And when I shut the power off the fan would act like a generator and powered the ign for a few seconds. My solution was, I put everything one it's own power lines. But if you have a fan and put the diode on the fan power line that should solve the problem. Good luck! Dave |
| Author: | plumberbill [ Thu May 10, 2007 8:08 am ] |
| Post subject: | |
all accessorys are on there own seperate fused circut |
| Author: | railridernky [ Thu May 10, 2007 7:31 pm ] |
| Post subject: | |
install a diode between alt light an voltage reg that will take care of it. been there done that. 15 or 20 cents at r.shack |
| Author: | kybuggy1 [ Thu May 10, 2007 10:48 pm ] |
| Post subject: | |
Wes, I think he already did that. [quote='plumberbill']diode is installed with the silver ring towards the alt. per msd ign. switch has been replaced[/quote] Larry |
| Author: | railridernky [ Sat May 12, 2007 11:45 am ] |
| Post subject: | |
must of had a brain malfunction. sorry |
| Author: | kybuggy1 [ Sat May 12, 2007 12:14 pm ] |
| Post subject: | |
LOL! |
| Author: | plumberbill [ Mon Jul 30, 2007 10:13 am ] |
| Post subject: | |
found out what the problem was, thanks to odyknuck who found a post on the samba. turns out i installed a new oil cooler with a fan, when the fan shuts down it back feeds a charge which appearently is enough to keep the ign. running for a few seconds. what made this a little more confusing is that i installed a thermostatic switch inline so the only time the problem appeared was when the oil temp got to 165deg. and kicked the fan on. simple fix, just had to install a diode on the power supply to the fan to keep it from back feeding. im really suprised that when i called msd tech support they never brought this up. sorta reminds me of going to the auto parts store, nobody thinks oudside the box. |
| Author: | Odyknuck [ Mon Jul 30, 2007 10:26 am ] |
| Post subject: | |
Bill,Read DVs,s post above yours about his oil cooler fan |
| Author: | plumberbill [ Mon Jul 30, 2007 9:02 pm ] |
| Post subject: | |
[quote='DVS1']Like Gusto said. But I can tell you from personal experience, I had everything on one wire ign,fuel and fan for the oil cooler. And when I shut the power off the fan would act like a generator and powered the ign for a few seconds. My solution was, I put everything one it's own power lines. But if you have a fan and put the diode on the fan power line that should solve the problem. Good luck! Dave[/quote] i swear his post didnt say anything about a diode on the power |
| Author: | Odyknuck [ Tue Jul 31, 2007 2:44 pm ] |
| Post subject: | |
Thats his story and he's sticking to it! |
| Author: | DVS1 [ Tue Jul 31, 2007 3:38 pm ] |
| Post subject: | |
Yeah, I was going to say something but i'll keep my mouth shut. |
| Author: | plumberbill [ Wed Aug 01, 2007 8:30 am ] |
| Post subject: | |
just my attention deficit disorder kicking in |
| Author: | bruce 1 [ Mon Aug 13, 2007 4:33 pm ] |
| Post subject: | |
where did you get the Diod? and what kind brand etc? Thanks |
| Author: | kybuggy1 [ Tue Aug 14, 2007 9:01 am ] |
| Post subject: | |
My new MSD box for my wife's buggy came with one, but I got one at Radio Shack for my old MSD box that I put on my buggy. Just asked them for a one way diode and the guy took me right to it. Larry |
