It is currently Mon May 04, 2026 4:33 am
 Post subject: Efi and dry sump?
PostPosted: Thu Aug 07, 2008 5:35 pm
What do you guys know about EFI and dry sump oiling?
I want to be able to do "high angle" driving :shock:
Do i need dry sump oiling for that?
Would eliminating float bowls help in extreme angle situations?
What other mods do I need to do to keep it alive?
Thanks for sharing
 Post subject: Re: Efi and dry sump?
PostPosted: Thu Aug 07, 2008 8:38 pm
Yes and Yes! For extreme vertical situations, a dry sump is a must. As far as EFI. i have it and like it but I have seen some people get very verticle with carbs and still kick ass. I know Roy has had both and I think he really likes the EFI.
PostPosted: Thu Aug 07, 2008 10:00 pm
Hill Climber
I am not ready to spend the money on EFI yet but from what I have seen it is worth it. I have not had a problem with my carbs on hills either. Hope I don't.
Harry S. Truman
PostPosted: Thu Aug 07, 2008 10:44 pm
What type of dry sump system would be OK? The only one (pump) I have seen is the C.B pump :?
PostPosted: Fri Aug 08, 2008 3:41 pm
CB pumps/tanks are all we use here.
Need to use a modified power pulley or a dry sump serpentine system like Dave and Steve have.
Normal pulley won't clear the pump.
PostPosted: Fri Aug 08, 2008 5:38 pm
high angle driving,thats funny,i dont have dry sump and we got some pretty long tall hills here and my single carb does great
PostPosted: Fri Aug 08, 2008 6:53 pm
The carb is not the problem.
It's all the oil getting away from the pickup and starving the bearings.
PostPosted: Fri Aug 08, 2008 7:01 pm
Ok so prioritys changed :? Now dry sump then efi gotta figure out the $ the Go :roll:
PostPosted: Fri Aug 15, 2008 11:08 pm
8)
PostPosted: Sat Aug 23, 2008 10:15 am
OK how wood this plumb in with my remote oil filter? :?
so ive got this so far
#1 bugpack pump
#2 bmd serpentine belt system with small pulley
#3 tank?
#4 oil filter
