It is currently Tue May 05, 2026 2:29 am
 Post subject: fuel octane and jetting
PostPosted: Tue May 06, 2008 8:31 am
how would 110 octane affect jetting on a 1600DP 34 pict-3?
PostPosted: Tue May 06, 2008 11:41 am
Usually makes it leaner.
If you don't have the compressio to support that octane it is a waste of money to use it IMHO.
Octane is the resistance to ignition.
Higher the octane, harder it is to light off.
Pump gas will fire before race gas unde the same conditions.
PostPosted: Wed May 07, 2008 10:16 pm
i ran that in my 1641 with a pic 34 it ran a little leaner plugs where still nice and brown though i idnt mess with anything i could tell a differnce in that small motor with that octane turboblue or cam 2 the cam 2 around our place is 525 compaired to turbo which is up around 6 a gallon
PostPosted: Fri May 09, 2008 12:31 pm
i just bought 10 gal of sunoco race fuel, it was 7.50 a gallon :cry:
PostPosted: Fri May 09, 2008 3:46 pm
they riped you a new one!!! I give $4.45 a gal. for Sunoco 114. Buy it by the drum and it will be cheeper.
PostPosted: Fri May 09, 2008 5:49 pm
propain 180 gal 120 oct
10to1
PostPosted: Sat May 10, 2008 12:37 am
Wow that is cheap! I'm paying $4.49/gal just for diesel.
PostPosted: Sat May 10, 2008 1:10 pm
Must be RACING DIESEL.
PostPosted: Sat May 10, 2008 2:14 pm
4.39 here Dave but that was an hour ago........ :x
PostPosted: Sat May 10, 2008 5:44 pm
$4.12 here this morning. $100 bill didnt even fill up my little 29 gallon tank :evil: :evil: :cry: :cry:
price gouging bastards
PostPosted: Thu Jun 19, 2008 7:34 am
I finally got the combination figured out with my engine the way it runs problem, I bought $300 worth of jets and venturi's to try to get the engine to run right, it has been a long process. I ended up putting in the 44IDF upgrade kit in it with 70 idle jets, 145 mains, and 200 air jets. It was running so well, I ended up breaking my 930 CV and stripped the axle this past Sunday, I was also running 5 gal. 93 octane pump gas and 2 gal 109 cam2 racing fuel. It is a 2276cc engine.
cron
