It is currently Mon May 04, 2026 6:25 pm
PostPosted: Wed May 28, 2008 9:42 pm
Hey guys I need a little advice
I have a 1641cc vw. I installed a new filter / pump from CB performance
I use 10w 30 oil, The engine was built 15 years ago and stored in a barn
intil I "found it". It's a dual relief case. The oil pressure ,engine warmed up, is 40psi at idle
and 60 to 80 psi at 4000 rpm. I have no idea what the pressure was before the new oil pump
was installed
Question What the heck is going on??
Thanks
BillMc
Help as many prople as you can. Be good to your friends. Expect nothing! Clean you webers before every trip!!!Bill Mc
PostPosted: Thu May 29, 2008 5:23 am
Those numbers seem a bit high, but they are not way out of range. The calibration of your pressure guage may be an issue.
Unusually high oil pressure is usually caused by a spun bearing or other oil galley component that is blocking flow, but you would have found that out by now (seized engine).
The only other suspect is your oil pressure regulating plunger(s) which may be sticking in their bores ...or have stronger-than-stock springs pushing on them.
a.k.a."PittsburghJim" on www.dune-buggy.com
PostPosted: Thu May 29, 2008 8:24 pm
I think I found the problem
The releif piston in the front by the oil pump
was frozen in the case. I used a 1/2" tap to cut threads
in the piston then used a bolt to remove it.
Now the oil pressure is 40 at idle and 60 at 4000 rpm
but never goes over 60. Much better!!
Thanks
Bill
