It is currently Mon May 04, 2026 6:30 pm
 Post subject: Fuel Line
PostPosted: Mon May 05, 2008 4:10 pm
What size fuel line are you guys using?
Jim
D. Marks wrote:
The only time I hug trees is while I'm carring them out of the way.
 Post subject: Re: Fuel Line
PostPosted: Mon May 05, 2008 11:11 pm
3/4 of an inch. No, seriously, it depends on what you are trying to feed. Although I think it's kind of small, I have spoken with people with street VW's that have been able to support up to 200HP on the stock 6mm VW fuel line. If you have a fairly healthy N/A engine, 100-150HP, 1/4 inch would work. The bigger the engine, the more volume it needs. If you have a turbo, or large stroker, you may want to use 3/8 for peace of mind. I have a friend that has the theory of "you can never have too large of fuel line". He had a 2332, that made around 260HP, in his street driven drag Beetle. He used a 1/2 inch line with return style regulator, and a 3/8 inch return. This to me is way overkill, but he never ran out of fuel.
PostPosted: Wed May 14, 2008 10:24 pm
I run # 6 steel braided line works and looks great
