 Post subject: crower cams
PostPosted: Sat Apr 26, 2008 10:55 pm
i was wondering if anybody has tried these cams i was thinking about trying the dual lobe in a 2332 any comments :? maybe crower 21004 or 21005 thanks
PostPosted: Sun Apr 27, 2008 7:19 am
The Crower dual lobe (split duration) camshafts work very well in VW engines. Especially if you are using heads that are cast on 040 through 044 castings. I usually pump them up by running 1.25 rockers with them.
PostPosted: Sun Apr 27, 2008 7:03 pm
roy i have o44 heads with a little work .also can use either 45 or 48 dells.could i use 1.4 rockers :?: or do you think 1.25 would be better :?:
PostPosted: Mon Apr 28, 2008 12:12 pm
If you use 1.4 rockers with those cams your lift will be extremely high. You may have valve to piston clearance problems. Something you will want to check. Check closely! Also check for coil bind and retainer to guide interference!
I recently built a 1915 motor for a friend (beeline dave) and he has worked over 044 heads and dual 40 webers.. We used a 61004 with 1.25's. The thing really runs excellent. I also used the same cam in the last 2276 I built with a single 45 Dell it really runs well.
PostPosted: Mon Apr 28, 2008 8:30 pm
roy thanks for info what kind of rpm do you think i could get :?: i will also have 5.7 rods i just got stock gears in a six rib and i think my bottom end will be alright was wondering on rpm though :? :? thanks
PostPosted: Tue Apr 29, 2008 1:36 pm
It will easily turn 7 grand with no problem.
