| need some serious help -please http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=3665 |
| Author: | duneracer01 [ Sun Apr 20, 2008 9:04 pm ] |
| Post subject: | need some serious help -please |
just had a 1915cc built but its not ideling right and when i take off it hesitates a little what is more likely gonna be my problem any and all help and info is appreciated. Phillip Peppers |
| Author: | vwtravis [ Sun Apr 20, 2008 9:14 pm ] |
| Post subject: | |
Sounds like the carb what kind do you have? |
| Author: | duneracer01 [ Sun Apr 20, 2008 9:18 pm ] |
| Post subject: | |
2brl progressive webber brand new |
| Author: | chris38375 [ Sun Apr 20, 2008 9:27 pm ] |
| Post subject: | |
are the chokes still in the carb.?sounds like u could have a vaccum leak somewhere,intake gasket or rubber boots leaking a little |
| Author: | vwtravis [ Sun Apr 20, 2008 9:57 pm ] |
| Post subject: | |
You mite have a intake gasket or boot leaking, or a idle jet plugged. Most every progressive iv worked on the pim. and sec. jet was to small dont know what size to use I jest use a torch tip dill set and open them up if you go to big you can solider it closed and start over. Or buy bigger jets. Also the smaller air bleed the richer it will be. Not for sure this is your prob. but it sounds like it. |
| Author: | Eric DeBord [ Mon Apr 21, 2008 7:14 am ] |
| Post subject: | |
If it is a new intake, most are too long and bottom out in the end castings and will not allow them to seat on the heads properly. Remove any mounting bolts and see if you can move the intake sideways in the castings. If not, then usually about and 1/8 to 1/4 cut off of each end is fine. |
