| dry sump http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=3485 |
| Author: | bruce 1 [ Mon Mar 31, 2008 7:03 pm ] |
| Post subject: | dry sump |
David I hope this helps. [quote='bruce 1']Do you run straight cut cam gears? If not you need too. There are 2 types of pumps to consider. 1st is a bug pack pump. It is the best one for woods riding and it is a 2 stage pump. A dry sump means you do not use a deep sump. The main purposes of a dry sump are to get the air bubbles out of the oil, oil to the bearings all the time, and cooler oil. How it works: The pump empties out the engine oil, and pumps it back to your sump tank, (so air c |
