It is currently Mon May 04, 2026 9:00 pm
 Post subject: pressure gauge wiring?
PostPosted: Wed Mar 19, 2008 11:01 pm
Ive got a vdo two post sender "g" "wk". Ive got gauge with"s" "i" "gnd". I also want to hook up idiot light. Anybody point in the right direction? Thanks Jason
PostPosted: Thu Mar 20, 2008 10:01 am
I just hooked this up on my buggy last weekend. The "g" on the sending unit goes to the "s" on the gauge. the "wk" on the sending unit then obviously goes to the idiot light. the other wire on the idiot light goes to 12 volts when the ignition switch is on. the "i" on the gauge should go to 12 volts when the key is on and the "gnd" on the gauge is obviously ground. I live in kent so let me know if you have problems and I will try to swing by and give a hand with anything I can. My number is 330-714-5160
PostPosted: Thu Mar 20, 2008 11:12 am
You know this is what I like about the buggy crowd, people are willing to help others when and where they can. I know when I first got into buggies I knew nothing. So many have helped me and answered my questions, now I try to pass on what I have learned to others that are new to the buggy addiction.
The Wild Kids
 Post subject: oil pressure gauge
PostPosted: Thu Mar 20, 2008 10:33 pm
got it wired up tonight along with volt meter. had 35-40 psi at idle, only let run for 1-2 minutes. is that good? what should pressure be at running temp? thanks for the help with wiring. Jason
PostPosted: Fri Mar 21, 2008 12:21 am
Looks good on the pressure, depends I guess on the oil that your using. Seems like you have plenty so far.
The Wild Kids
PostPosted: Fri Mar 21, 2008 10:00 am
90% of my posts on here have been asking for help from other people and I received all the info that I needed so it is an absolute pleasure to help someone else out. I have heard you only need 10 to 15 pounds at an idle at operating temp but like wild kid said it depends on the oil you are running. It sounds like you are doing pretty good to me. Do you know of any little places around our area for a shake down run? I will be driving my buggy for the first time next weekend and I don't want to take it far in case I have a problem.
PostPosted: Sat Mar 22, 2008 1:15 pm
I dont know of anywhere close around here. I will ask around and will let you know. Jason
PostPosted: Sun Mar 23, 2008 8:25 pm
If it won't upset the neighbors run it up and down the street in front of your house to get the motor warmed up and able to give it a mild going over at least. Good luck with it.
The Wild Kids
PostPosted: Sun Mar 23, 2008 8:26 pm
The Wild Kids
PostPosted: Mon Mar 24, 2008 9:57 am
Running it up and down the street is the plan for now. It has lights, turn signals and brake lights but isn't registered yet. I hope I don't p!$$ anyone off. There are alot of kids in the neighborhood so maybe the cool factor will work in my favor. Jason, let me know if you find anyplace to ride at. I know a couple small places but the legality is questionable and I don't want to be the guy to ruin it for others. Hopefully I can get some pics this week. I am still in the disposable camera stage of evolution. Its been a three year project and I can't wait to drive this thing.
PostPosted: Mon Mar 24, 2008 2:57 pm
there is a little place here in zanesville to ride. think thats about an hour from you guys. you can call me up anytime you want and i can take ya there. 740-819-9173
kyle
"Lets go get stupid"
