 Post subject: NEW MOTOR
PostPosted: Tue Mar 11, 2008 5:37 pm
I am curently getting a 2276 built and I am wonder what the life span of my 3rib will be with my heavy right foot or should I make the upgrade to a 6rib asap
This one time at wellsville
PostPosted: Tue Mar 11, 2008 5:43 pm
That or a super diff.
aaron
PostPosted: Tue Mar 11, 2008 6:27 pm
Will it take that kind of power though
PostPosted: Tue Mar 11, 2008 6:32 pm
any thing will break,I could never get a 6 rib to stay together .It's all about HP and the way you drive .Like Gizmo said." if it feels good, hold it to the floor & pour it to it"
PostPosted: Tue Mar 11, 2008 7:26 pm
Welcome to The Site!
Wouldnt waste my time bolting that motor up to a stock 3 rib, unless you like to REALLY baby it.
Larry
PostPosted: Tue Mar 11, 2008 7:29 pm
I agree with Larry. Don't waste your time with the 3 rib. Even if you put a super diff in it you will break first gear in no time. Use a 6 rib with a super diff. Then save your money for a set of Weddle gears and upgrade to that later.
PostPosted: Tue Mar 11, 2008 7:40 pm
What kind of money are those gears
PostPosted: Tue Mar 11, 2008 7:44 pm
First and second set is about 550 bucks. 3 and 4 are about 250 each. Maybe a little more I heard they have gone up slightly. (just like everything else)
PostPosted: Tue Mar 11, 2008 8:34 pm
[quote='Roy']First and second set is about 550 bucks. 3 and 4 are about 250 each. Maybe a little more I heard they have gone up slightly. (just like everything else)[/quote]
I hate to say this.....but it went up to 650 for 1st and 2nd gear set and 300 a piece for 3rd and 4th gear, just got mine done (091-6-rib) Sunday.
PostPosted: Wed Mar 12, 2008 5:08 pm
How long did it last befor it broke and how heavy is your right foot
PostPosted: Wed Mar 12, 2008 5:48 pm
i break 3 ribs with a 1641.wouldnt even try that motor on a 3 rib.
PostPosted: Wed Mar 12, 2008 5:54 pm
I ran a 3 rib for 3 years with a 1915 and I was not nice to it :twisted: Finally broke the diff,It all depends on how you drive it dumping the clutch all the time when you take off is really hard on them,I have been through more reverse gears than anything!You could always go chaindrive then it would save alot of destruction :lol:
aaron
PostPosted: Wed Mar 12, 2008 10:32 pm
I left third and fourth gear stock in my 6 rib. Ijust don't hammer in those two gears and i saved some money.
PostPosted: Thu Mar 13, 2008 3:54 am
I've got almost 4 years on my 3 rib with a 1915 and I drive the hell out of it. Just put reverse in it for the first time also. Depends I guess on the tranny to begin with. I have seen 3 ribs break on the first outing also. 091 you cant beat it and I would recommend it for your 2276
The Wild Kids
PostPosted: Thu Mar 13, 2008 9:20 am
The 3-rib has 2 main weak points. The 3-ribs that have the "acorn" nuts behind the cv flanges are even worse as the pinion bearing setup inside is a very poor design. The first weakness is the first gear. This can be upgraded to the late style "super beetle" 9-tooth mainshaft (instead of the 10 tooth one that is normally in it). This will make 1st a lot stronger. The 2nd weak point is the ring and pinion and about 8 out of 10 I take apart are bad. I do not recommend a 3-rib for ANY abuse even with a small engine. I suggest either a 5 or 6-rib trans. For abuse, a superdiff and racing mainshaft are also needed.
PostPosted: Thu Mar 13, 2008 9:36 am
Eric what is your opinion of the side shift water boxer vanagon transmissions? :?
PostPosted: Thu Mar 13, 2008 5:29 pm
Dont know much about those but I am in the process of geting a 6rib dune up its his tranny and he is going all through it and in stalling a super dif its kind of nice when you have the money shit starts to happen now if I get the chance to ride with you guy i will have a buggy worth beatin
