 Post subject: cam info for 2387
PostPosted: Tue Feb 12, 2008 7:11 pm
I have a 2387 with a fk8 cam, 1.4 ratio rockers and s/f heads.My motor will lug around fine. My problem is only in reaching power band in hard pulls in 2nd. I have a six rib with a faster first and a slower 2nd.I am changing my cam to a fk44, It has .547 lift and a 287 duration. Do you you think this will help my problem? Has anyone tried the fk44 cam?
PostPosted: Tue Feb 12, 2008 9:56 pm
That will help a little but the main reason for this is the S/F heads. IMHO
PostPosted: Tue Feb 12, 2008 11:53 pm
I agree w/ Roy. I have the same size motor , but with an Engle 110 & 1.4 rockers, and highest first and lowest second Weddle had available. I think our cams are somewhat comparable to each other. I had S/F's at first, because I got them in a deal. Motor felt strong enough upstairs, and would lug decent, but not the midrange pull I wanted. Switched to Street Eliminators and it made a helluva difference. But even still, in a 1350 (or so) lb. buggy, it still wont pull a steep,long hill in second without a running start. And doing that I cant get in and out of the throttle and expect RPMs to recover well w/o downshifting. Guys who climb badass hills in second usually have what is referred to as "second gear trannies" (6 ribs w/custom R&P and gears), and you need a healthy 2500 to pull one of them even.
I guess all that depends on what you are tryin to pull in second, too. :wink:
Larry
PostPosted: Wed Feb 13, 2008 9:19 am
I am now running dual 44 webers with 38 venturies. If I change to 36's, will that help some with my problem?
Thanks for any help.
PostPosted: Wed Feb 13, 2008 10:45 am
The 36s will help speed up the Velocity at lower RPMs and that will increase your low end Torque. It lowers your top end however unless your concerned about 1/4 mile ETs I would not worry about it.
PostPosted: Wed Feb 13, 2008 1:23 pm
That will help it. I got Weber 44's and ordered the smallest vents I could get. Helped throttle response quite a bit. I think they are 34mm. Wont notice the loss at WOT in the woods.
Larry
