| 5.7 rods http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=2931 |
| Author: | steaminmikado [ Mon Feb 04, 2008 4:01 am ] |
| Post subject: | 5.7 rods |
hey guys, i've seen some advertisement on 5.7 rods.... are they wam bam thank you mam deal or what? any modification to make? does it make a stroker or what? just wondering. |
| Author: | bruce 1 [ Mon Feb 04, 2008 8:16 am ] |
| Post subject: | |
Much Much more info is needed. what do you have now?????????? |
| Author: | steaminmikado [ Mon Feb 04, 2008 11:54 am ] |
| Post subject: | |
building a 1914 right now. |
| Author: | Odyknuck [ Mon Feb 04, 2008 12:04 pm ] |
| Post subject: | |
5.7 rods are typically used for larger stroke motors and give you more top end due to the time the piston stays at TDC. You would have to use cylinder spacers on those. I would opt for a shorter rod. |
| Author: | steaminmikado [ Mon Feb 04, 2008 5:18 pm ] |
| Post subject: | |
that answers my q. so basically it's not real pheasable in a small engine? |
| Author: | Odyknuck [ Mon Feb 04, 2008 6:10 pm ] |
| Post subject: | |
Yes. I take it from your screen name your into Trains. |
| Author: | Roy [ Tue Feb 05, 2008 10:30 am ] |
| Post subject: | |
You could use the long rods in a 1915 but they would raise the power band quite a bit. You would loose low end. They are great for drag racing if you want to turn very high rpm's with big flow heads. Not the best choice for a stock stroke crankshaft in a woods buggy. |
| Author: | steaminmikado [ Tue Feb 05, 2008 6:58 pm ] |
| Post subject: | |
thanks guys. like i said, i'm putting mine together and i've just heard and read about some 5.7 rods in vw's. i'm going to stay w/my stock crank & rods for now. something just to go wumdin wumdin. odyknuck, you're right about the train thing. you and kurt are the only ones that's caught on to it in the several years i've used this screen name. my dad and i are members of a scaled down train club in tenn. by the way.. what is a good cam to use on a 1914 buggy motor? ummm, for right now i've got stock duel port heads and a single dellorto 40. |
| Author: | Roy [ Tue Feb 05, 2008 8:49 pm ] |
| Post subject: | |
Engle 110 works great with that combo. Another one that works great is the VZ-15. Okie has that in his 1915 with stock heads and it runs really well. |
| Author: | steaminmikado [ Wed Feb 06, 2008 12:40 am ] |
| Post subject: | |
my buddy was talking about a "tractor cam." any thoughts? said he's run it for years. then he stepped up to bigger and better combinations of 2180's with a vz 15 cam i think. how should i expect the vz15 cam to run with a "stock" setup with a single carb compared to a tractor cam? like where's is "powerband" on the vz cam? |
| Author: | buggy66 [ Wed Feb 06, 2008 9:26 am ] |
| Post subject: | |
I am running a vz15 in a 2276 w/ stock heads----- lots of low end torque!!! If you want more top end then go bigger valves. For the 1915 I would use the vz14 w/ stock heads! |
| Author: | travisdunebuggy [ Wed Feb 06, 2008 7:49 pm ] |
| Post subject: | cams |
speakn of cams does any one know where i can get a crower 61004 cause thats what i had in mine but one of the lobes went down and i already had a scat c35 cam its good but the crower came on quicker and the motor seemed louder than it does now ;comments please !!!! |
| Author: | rockrockets1 [ Wed Feb 06, 2008 10:12 pm ] |
| Post subject: | |
do you have 2 carbs if so it will not lope single carb will hit a lick 2 will not |
| Author: | Kyle [ Wed Feb 06, 2008 10:15 pm ] |
| Post subject: | |
[quote='rockrockets1']do you have 2 carbs if so it will not lope single carb will hit a lick 2 will not[/quote] interrested. whats the reason behind this rock? kyle |
| Author: | travisdunebuggy [ Wed Feb 06, 2008 10:40 pm ] |
| Post subject: | |
[quote='rockrockets1']do you have 2 carbs if so it will not lope single carb will hit a lick 2 will not[/quote]I have 2 delorto 46's now the next question is why not ?????????? |
| Author: | steaminmikado [ Thu Feb 07, 2008 2:41 am ] |
| Post subject: | |
rock, which will lick out a hit? the vz cam? |
| Author: | rockrockets1 [ Thu Feb 07, 2008 9:24 am ] |
| Post subject: | |
Travis you either have 40,45 or48 did not make 46 . some thing about equal flow with two carbs you take two off put one on and you will here the cam let's ask Roy |
| Author: | travisdunebuggy [ Thu Feb 07, 2008 12:05 pm ] |
| Post subject: | |
yea there45's i must have hit the wrong key |
| Author: | sdbillyg [ Thu Feb 07, 2008 9:17 pm ] |
| Post subject: | |
with a single part of the fuel mixture gets pushed back up the intake for a second that cylinder goes lean and has a miss so you get a rough idel.with duals the mixture has no where to go so you have a better idel i think it is called intake revision or something like that. |
| Author: | Kyle [ Thu Feb 07, 2008 10:13 pm ] |
| Post subject: | |
well i guess i like the sound of my rough idle then hehe |
