 Post subject: Roy I need help
PostPosted: Sun Jan 13, 2008 7:43 pm
last night we were at the dome Karen's buggy sat in the arena drove it in just fine gave it a couple good revs still fine parked it for a couple hrs when she started it up it had 0 oil pressure took off the full flow line nothing what you think
PostPosted: Sun Jan 13, 2008 7:53 pm
I don't know? Broken oil pump maybe? I don't know what kind of motor she even has on her car. :? A/C VW?
Something has to have broken. I suspect oil pump. Pull off the cover and turn motor by hand. See if gears rotate.
Maybe pick up tube came loose?
PostPosted: Sun Jan 13, 2008 7:55 pm
2276 vw sorry i never ran in to this
PostPosted: Sun Jan 13, 2008 8:15 pm
If you pulled off the oil line from the oil pump cover and nothing was being pumped out I suspect something is wrong with the oil pump. Process of elimination from this point. Hopefully it is not serious.
PostPosted: Sun Jan 13, 2008 8:33 pm
thanks i'll start there
PostPosted: Sun Jan 13, 2008 9:24 pm
If the oil pump is not turning pull it out and see if the cam is turning.
PostPosted: Mon Jan 14, 2008 12:31 am
Does it have dry sump? Some dry sump pumps use woodruff keys that can shear. My buddy's did it for no apparent reason. Replaced it and its been fine for 3 - 4 rides.
Larry
PostPosted: Mon Jan 14, 2008 5:24 am
I doubt it is dry sump. He said in one of his posts that he pulled off a full flow hose. Full flow usually means regular oil pump.
PostPosted: Tue Jan 29, 2008 5:23 pm
well I finaly got time to take a look the oil pump part that fits in the cam the drive i guess broke off smoth i got the piece it was very cold that night the oil was thick and it was time to change the oil filter and oil .I just dont know ever had this?
