It is currently Mon May 04, 2026 12:56 pm
 Post subject: 90mm stroke engine
PostPosted: Mon Jan 07, 2008 4:14 pm
Anybody here built a 90mm stoke VW engine? If so what did you have to do to do it other than clearencing the case and cam. What case you used etc.
 Post subject: Re: 90mm stroke engine
PostPosted: Mon Jan 07, 2008 6:48 pm
[quote='Odyknuck']Anybody here built a 90mm stoke VW engine? If so what did you have to do to do it other than clearencing the case and cam. What case you used etc.[/quote]
Getting ready to order all the parts for a 2498cc 94 x 90mm engine.
CB 7.5mm raised deck alum. case.
DPR 90mm crank
CB 5.7 Buick journal H beam rods.
FK8 camshaft, stroker notched.
Need a little extra clearance on cam bearing towers, little deeper notches in cam (don't lathe turn it), bit more rod bolt
PostPosted: Mon Jan 07, 2008 10:32 pm
Gary does the motor need the longer cylinders or does the 7.5mm high cylinder deck take care of it. I would assume my case is standard considering it only has a 78mm crank and would have to add cylinder shims.
PostPosted: Tue Jan 08, 2008 11:28 am
[quote='Odyknuck']Gary does the motor need the longer cylinders or does the 7.5mm high cylinder deck take care of it. I would assume my case is standard considering it only has a 78mm crank and would have to add cylinder shims.[/quote]
The raised deck compensates for the longer cylinders.
You still may have to shim accordingly to achieve the desired deck and compression.
This case allows you to keeps those to a minimum.
PostPosted: Tue Jan 08, 2008 12:09 pm
Just so Im clear here, are you saying you do not need longer cylinders and just shim the stock length cylinders to get the required deck height. I ask because I have heard that you need to go with longer cylinders because of the increased stroke and required length of rod to run thew longer stroke.
PostPosted: Tue Jan 08, 2008 5:18 pm
[quote='Odyknuck']Just so Im clear here, are you saying you do not need longer cylinders and just shim the stock length cylinders to get the required deck height. I ask because I have heard that you need to go with longer cylinders because of the increased stroke and required length of rod to run thew longer stroke.[/quote]
The long cylinders are theoretically just longer from where they sit on the case to the end that seals on the head.
I can't find the paperwork on the last one
PostPosted: Tue Jan 08, 2008 7:52 pm
Gary, do they make a raised deck mag case? or are they all aluminum?
PostPosted: Tue Jan 08, 2008 8:32 pm
[quote='Eric DeBord']Gary, do they make a raised deck mag case? or are they all aluminum?[/quote]
All aluminum AFAIK......... :(
PostPosted: Tue Jan 08, 2008 9:14 pm
turbo you da man :razz:
PostPosted: Wed Jan 09, 2008 1:16 pm
[quote='rockrockets1']turbo you da man :razz:[/quote]
I don't know about that but I have stayed at a Holiday Inn.......... 8)
PostPosted: Wed Jan 09, 2008 6:33 pm
Now thats Funny, I dont care who you are :lol:
