Sand Seal pullys
http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=2039
Author:  Odyknuck [ Wed Nov 28, 2007 4:52 pm ]
Post subject:  Sand Seal pullys
How many of you guys are running Sand seal Pullys in your Woods Buggys. Also if your not have you had any issues with dirt in your motor?
Author:  Roy [ Wed Nov 28, 2007 6:22 pm ]
I run one to KEEP the dirt out.
Author:  Blake [ Wed Nov 28, 2007 6:31 pm ]
10-4 Roy, me too!
Author:  DVS1 [ Wed Nov 28, 2007 9:56 pm ]
Mine's sand sealed also. Roy and I both have the B&D serpintine belt sand sealed system for our dry sump systems. Don't you have a dry sump also, Steve? I think the B&D dry sump pulley system is the best you can get, no modifications. And Gary (Turboblue) sells them for a very good price.
Author:  Odyknuck [ Wed Nov 28, 2007 10:09 pm ]
I run a Sand seal set up . I was just curious how many others do and if those that dont have issues. Are you guys running the machine in style or press in.
Author:  purplerail [ Wed Nov 28, 2007 10:11 pm ]
hey dave i like your belt system. what kind of cost fo complete system?
Author:  frankenbuggy06 [ Thu Nov 29, 2007 4:08 pm ]
one of the guys i ride with bought the buggy from my cousin and it has a sand seal but it tends to slide out. espically in the sand. but idk if its just because of the timje it has been in there
Author:  sharpshooter [ Thu Nov 29, 2007 10:32 pm ]
sand seal, me too :D
Author:  Firebug [ Thu Nov 29, 2007 10:44 pm ]
sand seal :?:
Author:  sharpshooter [ Thu Nov 29, 2007 11:41 pm ]
waterbaby its a ac thing you wouldnt understand :lol: :lol:
Author:  railridernky [ Fri Nov 30, 2007 8:54 am ]
Sand seal here.
Author:  kybuggy1 [ Fri Nov 30, 2007 9:07 am ]
Sand seals x 3!!
Author:  RaceBugg1098 [ Fri Nov 30, 2007 9:12 am ]
i run a scat slinger type on my newest motor, i couldn't keep the seal in the sleeve, or the sleve in the block with a sand seal
Author:  Odyknuck [ Fri Nov 30, 2007 3:32 pm ]
RaceBugg1098 are you talking about the press in style with the sleeve? I dont like those. I prefer the machine in style. They are basically a standard seal however the case has to be bored out to use them.
Author:  RaceBugg1098 [ Fri Nov 30, 2007 4:17 pm ]
yes, i ran the sleeve type. i ran it for years with no problem, but my last 2 motors they won't hold up. i just figured that the thrashing that racing puts on it (some times 4 hours straight of 3500-6400 rpm) was too much.
Author:  vw505 [ Mon Dec 31, 2007 8:29 am ]
sand seal and i used weather strip adhesive to hold them in
Author:  DubVee1835 [ Mon Dec 31, 2007 6:43 pm ]
I have a question about the sand seal... Say im climbing a hill and dont make it, And while backing down i get up against a tree at a pretty good angle and while it sits there oil leaks out around my pulley.... would a sand seal prevent this or just slow it down?? Thanks
Author:  sharpshooter [ Tue Jan 01, 2008 1:01 am ]
It keeps it from leaking out,or dirt getting in
