It is currently Mon May 04, 2026 12:57 pm
 Post subject: Sand Seal pullys
PostPosted: Wed Nov 28, 2007 4:52 pm
How many of you guys are running Sand seal Pullys in your Woods Buggys. Also if your not have you had any issues with dirt in your motor?
PostPosted: Wed Nov 28, 2007 6:22 pm
I run one to KEEP the dirt out.
PostPosted: Wed Nov 28, 2007 6:31 pm
10-4 Roy, me too!
PostPosted: Wed Nov 28, 2007 9:56 pm
Mine's sand sealed also. Roy and I both have the B&D serpintine belt sand sealed system for our dry sump systems. Don't you have a dry sump also, Steve? I think the B&D dry sump pulley system is the best you can get, no modifications. And Gary (Turboblue) sells them for a very good price.
PostPosted: Wed Nov 28, 2007 10:09 pm
I run a Sand seal set up . I was just curious how many others do and if those that dont have issues. Are you guys running the machine in style or press in.
PostPosted: Wed Nov 28, 2007 10:11 pm
hey dave i like your belt system. what kind of cost fo complete system?
PostPosted: Thu Nov 29, 2007 4:08 pm
one of the guys i ride with bought the buggy from my cousin and it has a sand seal but it tends to slide out. espically in the sand. but idk if its just because of the timje it has been in there
PostPosted: Thu Nov 29, 2007 10:32 pm
sand seal, me too :D
PostPosted: Thu Nov 29, 2007 10:44 pm
sand seal :?:
PostPosted: Thu Nov 29, 2007 11:41 pm
waterbaby its a ac thing you wouldnt understand :lol: :lol:
PostPosted: Fri Nov 30, 2007 8:54 am
Sand seal here.
PostPosted: Fri Nov 30, 2007 9:07 am
Sand seals x 3!!
PostPosted: Fri Nov 30, 2007 9:12 am
i run a scat slinger type on my newest motor, i couldn't keep the seal in the sleeve, or the sleve in the block with a sand seal
PostPosted: Fri Nov 30, 2007 3:32 pm
RaceBugg1098 are you talking about the press in style with the sleeve? I dont like those. I prefer the machine in style. They are basically a standard seal however the case has to be bored out to use them.
PostPosted: Fri Nov 30, 2007 4:17 pm
yes, i ran the sleeve type. i ran it for years with no problem, but my last 2 motors they won't hold up. i just figured that the thrashing that racing puts on it (some times 4 hours straight of 3500-6400 rpm) was too much.
PostPosted: Mon Dec 31, 2007 8:29 am
sand seal and i used weather strip adhesive to hold them in
PostPosted: Mon Dec 31, 2007 6:43 pm
I have a question about the sand seal... Say im climbing a hill and dont make it, And while backing down i get up against a tree at a pretty good angle and while it sits there oil leaks out around my pulley.... would a sand seal prevent this or just slow it down?? Thanks
PostPosted: Tue Jan 01, 2008 1:01 am
It keeps it from leaking out,or dirt getting in
